Reuleaux Coaster
What’s better than a cool build? A cool build with valuable advice! Add a few flashy pictures and you have [Martin Raynsford]’s Reuleaux triangle coasters blog post. [Martin Raynsford] wanted to share his advice about the importance of using jigs and we’re sold. He was able to make 100 coasters in a single day and if he’s like us, after number ten, the work gets a little hurried and that is when mistakes are made.
Jig is a broad term when it comes to tooling but essentially, it holds your part in place while you work on it. In this case, a jig was made to hold the coaster pieces while they were glued together. [Martin Raynsford] didn’t need any registration marks on the wood so even the back is clean. If you look closely, the coaster is two parts, the frame and the triangle. Each part is three layers and they cannot separated once the glue dries. If any part doesn’t line up properly, the whole coaster is scrap wood.
This robot arm engraved 400 coasters in a day but maybe you would prefer if you simply had your beer delivered to your new coasters.
15 thoughts on “Reuleaux Coaster
  1. Without a sealant, are these coasters going to have issues with, well, being coasters and absorbing moisture or growing mold?
    Also, you can buy drills that are similarly shaped that are able to drill square holes.
      1. Called a watts chuck. Made by Watts Brothers Tool Works in PA. They dont have a website, you just have to call the old fashioned way. Last I saw the chuck is about $300, the bits are $100, and the guide is $75.
  2. As someone else mentioned earlier, get a mortising bit, used by woodworkers doing mortise and tenon work (though serious folks just chisel out the square edges thenselves). They used to cost at least $100 for say a Delta model, or more for a higher quality one, and sometimes came with a guide IIRC. I never buy still bits from HF after a couple of bad experiences, but they apparently carry these for just $13 here in the states. YMMV
    https://m.harborfreight.com/12-in-mortising-bit-and-chisel-68679.html?utm_referrer=direct%2Fnot%20provided
    Someone else mentioned a rotary broach as well. That has been featured here before as well, if you prefer making your own .
    https://hackaday.com/2014/05/26/achievement-unlocked-drill-a-square-hole-with-a-rotary-broach/
Leave a Reply to maconaCancel reply
