Retrotechtacular: Constructing A Car Engine
Oxford is a city world-famous for its university, and is a must-see stop on the itinerary of many a tourist to the United Kingdom. It features mediaeval architecture, unspoilt meadows, two idylic rivers, and a car plant. That’s the part the guide books don’t tell you, if you drive a BMW Mini there is every chance that it was built in a shiny new factory on the outskirts of the historic tourist destination.
A 1930s Morris Ten Series II. Humber79 [CC BY-SA 3.0].
The origins of the Mini factory lie over the road on a site that now houses a science park but was once the location of the Morris Motors plant, at one time Britain’s largest carmaker. In the 1930s they featured in a British Pathé documentary film which we’ve placed below the break, part of a series on industry in which the production of an internal combustion engine was examined in great detail. The music and narration is charmingly of its time, but the film itself is not only a fascinating look inside a factory of over eight decades ago, but also an insight into engine manufacture that remains relevant today even if the engine itself bears little resemblance to the lump in your motor today.
Morris produced a range of run-of-the-mill saloon cars in this period, and their typical power unit was one of the four-cylinder engines from the film. It’s a sidevalve design with a three-bearing crank, and it lacks innovations such as bore liners. The metallurgy and lubrication in these engines was not to the same standard as an engine of today, so a prewar Morris owner would not have expected to see the same longevity you’d expect from your daily.
The film starts with forgings, and the manufacture of crankshafts, gears, and connecting rods from forging, machining, and grinding, to the drilling of oilways. It is at this point we see the first of a series of specialised automatic machine tools and grinders, showing us the scale of the Morris operation at the time. We move on to castings, and see a freshly-cast engine block being ground, milled, drilled, and tapped. The sheer numbers of drills and taps in a single machine are impressive, though if you’ve ever broken a tap in an engine block you’ll probably be wincing a little. The die-cast pistons are next to be machined, and their oulways are reilled with yet another specialist multi-way drilling machine.
A number of components such as camshafts and gudgeon pins are turned from bar stock, their faces being case-hardened where necessary. The engine may have significantly changed over the years, but as anyone who’s had a modified camshaft built will tell you this is a recognisable process in the manufacture of their modern equivalents. Surprisingly we also see small components such as screws being manufactured, where today a specialist screw supplier would be called upon to bring them in ready-made, in the 1930s Morris saw fit to manufacture their own.
The film concludes with a montage of the engine assembly line, during which we see the archaic coil-spring clutch, flat sidevalve head, and camshaft drive. There is an interesting continuity error here, in that some of the engines being assembled are Morris’s six-cylinder unit rather than the 4-cylinder one we saw earlier, but we’ll forgive the producers that one.
The unjustly unloved Morris Marina. Felix O [CC BY-SA 2.0]
It is probable that a few of the processes in the 1930s engine factory would be recognisable in its modern equivalent, but it is also obvious that this is an archaic factory by today’s standards. Surprising is the high level of machine tool automation at a time when numerical control was probably not even a gleam in [Joseph Gerber]’s eye, but it is worth remembering that as the largest carmaker in the country the Morris factory would have represented the absolute cutting edge of automotive manufacture. You’re looking at the 1930s Tesla Gigafactory.
We mentioned earlier that the factory in this film is now no longer in existence. Morris had by the late 1960s become a component of the nationalised British Leyland group of carmakers as the British government tried to arrest the decline in the industry. By the 1970s the name appeared only on the Morris Marina, a car with an outdated 1950s design in a 1970s body that has become the butt of countless jokes about the Leyland cars but which your scribe can tell you from personal experience was excellent for drifting on wet roundabouts when her parents had one as the family car in the 1980s. In the early 1990s the original works was closed and demolished, with production of cars then badged as Rovers moving across the road to the site of Morris’s pressed steel works. A controversial ownership change left that operation in the hands of BMW, and it remains the base of their British operation. Meanwhile Morris cars are a regular sight on the classic car circuit, and there are still a few old guys driving Minors and Marinas round Oxford that they bought before retirement from the plant.
18 thoughts on “Retrotechtacular: Constructing A Car Engine
  1. The Morris Marina! I spent many hours fighting with my brother in the back of that turd colour car, no seat belts, travelling to see the Grandparents at Christmas! Nice to see it get a little love and a mention, even if only via rose tinted glasses. :)
  2. I grew up in Oxford, about a mile from the car plant. In those days (70’s) you could smell the fumes from the paint shop when the wind was in the right direction. Some of the buildings, and one of the chimneys still had traces of the camouflage paint used during the war.
    Embarrassingly, I actually *owned* one – an ‘Ital’, which was an effort to restyle the tired old Marina. Underneath, it was still a tired old Marina. The benefits of owning such an old car was that you could still work on it. My petrol pump gasket made from a used milk carton worked perfectly well!
    1. The benefit was you could work on it, the penalty is you *had* to work on it…
      My dad had a Marina, swore never to buy anything made by BL again.
      1. My Dad brought a 78 Marina in the early 80s as a run about. Due to the bad press, he expected it to last a few years. It run until the mid-to-late 90s, clocking up 375,000 miles before tin worm killed it off. I think a lot of the BL “experience” was the variable assembly quality.
  3. Unless it’s an aluminum block, you generally won’t find cylinder liners in use. (Chevy Vega serving as reason why you need them)
  4. This saddens me, to see what British industry was and is now a shadow of what it was, how has this been allowed to happen ?.
    1. Because it’s more efficient to (for example) have a factory that specialises in producing just screws, rather than each manufacturer building it’s own on site. So instead of one monolithic factory producing everything, industry has been spread out into many smaller firms, all making components. Some of those firms have moved overseas, but the UK is still a the front of a lot of automotive technology. For example, the majority of Formula 1 teams are based in the UK, (most not that far from Oxford actually).
    2. Post-war the country went to shit because of huge debts, rationing, shortages, all sorts of stuff, big businesses were run by an old boys club of Lords and gentlemen who often had zero skills / competence, management was terrible, unions grew massively powerful and made ever more crippling demands, foreign imports started being very competitive, then stuff got nationalised and went even further down the shitter… then Maggie turned up, bust heads, broke stuff up & sold it all off – anything worth anything basically got stripped and often went abroad.
      Manufacturing was very unfashionable when the boys in the city could make millions sat at a desk in Canary Wharf, that period set us back massively in terms of making stuff as it was envisaged that 1st world superpowers shouldn’t trouble themselves with the dirty jobs, we should just all be busy selling each other financial services and getting the developing countries to do all the makings.
      As an example, the original Mini cost more to make than they sold it for due to the engineers not wanting to question the price target set by the chairman.
  5. another great car engine video: The Invention of the Ford V8 Engine
    https://www.youtube.com/watch?v=3RB3z1er9Sw
    btw HadD editors, you might want to link previous articles touching on similar subject, like https://hackaday.com/2016/03/03/broken-promises-of-the-wankel-engine/
    maybe there are even WP plugins that automagically search and generate previous stories suggestions
    umm gigafactory is the battery, not the car one
  6. This could be a brilliant future for America manufacturing: providing spare parts to Cuba and all retro car lovers in the world
    1. A car is a way of getting from A to B. It needs onboard energy storage (battery or petrol/diesel), and a way to convert that stored energy into propulsion. Electric is good in so many ways, but energy storage i.e. electric battery vs. petrol/diesel, has a long way to go.
      In street parlance, “sparks don’t last”.
      Also, if your car or motorcycle is used for the journey (not the destination), electric doesn’t match the visceral appeal.
      I can see fossil-fueled engines for daily drivers becoming passe within a decade or two, but there’ll always be the appeal of a throbbing, noisy air-breather under your foot (or between your legs).
  7. “Surprising is the high level of machine tool automation at a time when numerical control was probably not even a gleam in Joseph Gerber’s eye”
    There are still factories, which use mechanical ways of controlling pretty complex manufacturing process. MrPete222 published several months ago a video from his trip to a factory making small parts, and using fully automated machines controlled by cams and levers. It’s a pleasure to watch them move, but it’s a great pain to change the program. You have to pick the right parts, and then assemble them in a very specific way. Numerical control is a gift from gods.
    https://www.youtube.com/watch?v=BF1TcwuRT50
Leave a Reply to TheOldEmptyBarnCancel reply
