Mini LEGO Technic Tank Patrols Your Desk Under ESP32 Control
We probably don’t have to tell the readers of Hackaday that LEGO isn’t just for kids; we’ve seen plenty of projects that live in an enclosure made of the multi-color bricks, and let’s not even get started on the Mindstorms builds we’ve seen over the years. But while LEGO (and especially the Technic product line) is fine for prototyping and putting together quick projects, the stock electronic components aren’t exactly top of the line. Which is why [Jason Kirsons] has been working on bridging the gap between LEGO and “real” parts.
His LEGO Technic tank is a perfect example of this principle. While the tank design itself is standard LEGO fare, he’s gone all in on the electronics. With an Adafruit Feather ESP32, custom motor controller board, and NEMA 8 steppers with 3D printed Technic adapters, this little tank has a lot more going on under the hood than you might expect. While this project is more a proof of concept than anything, the methods [Jason] demonstrates might be something to consider the next time you’re building with Billund’s best.
[Jason] chose the Feather ESP32 because of its small size, but you could get away with a generic board if you’re not trying to compress everything down into such a small footprint. Of course, if you go with another board you won’t be able to use the PCB he’s designed which attaches to the Feather and holds four Pololu DRV8835 motor drivers.
Easily the most broadly applicable element of this project is the work [Jason] has done designing adapter plates that let you use NEMA 8 motors with LEGO Technic parts. He’s put the adapters up on Thingiverse, for anyone looking for a drop-in solution to give their Technic creations a bit more oomph (technical term).
LEGO has a long history with hackers and makers. We’ve covered some absolutely incredible projects built with the famous construction set, and we don’t see any sign of it slowing down in the future.
[Thanks to Adam for the tip.]
11 thoughts on “Mini LEGO Technic Tank Patrols Your Desk Under ESP32 Control
  1. Lego is overpriced, and the patent ran out. Unfortunately Chinese copies don´t venture much in the Technics direction. It´s very limited. I wish they would do big boxes of generic construction element, but they are unfortunately oriented to cars and other machines, with way too much (useless) specific parts. Otherwise, even if the tolerances are *slightly* different sometimes, the copies are really good enough.
    China, can you hear me? make big boxes of many technical elements !
    1. LEGO does cost more, but I’ve found the Cheap Chinese Commie clone crap to be weaker at coupling to each other,
      it is is possible they do not use the tighter tolerances and higher pressures injecting the plastic into the molds.
      Maybe they are using an inferior plastic with lead based pigments as well…
    2. Specific parts? I’ve just looked over the the last 8 sets released and out of the total of 2632 pieces there was 1 unique part – which was a wheel arch of a licenced Corvette set.
      But china are already on it if you take a look on aliexpress you can get sets of gears and techinic construction pieces – I doubt it’ll be the same quality but depends what you need it for.
      Have fun!
    3. I find that having these so called “useless” parts is quite useful. sure some of the wheel hubs really are not particularly useful but even some of the “plating” can be very helpful for super structures and the variety of parts you get is also very helpful.
  2. Pretty neat, but I can’t seem to find those steppers for less than $13 each, shipped from China and $25 US. However, the 28BYJ48 stepper AND Lego part 6538 (cross-axle extension) shoved on the output shaft gives you a Lego compatible stepper. I can get 5 of those 28BYJ48s with driver boards for $14 shipped. Shouldn’t take more than 2 hours to design and print a Lego mount for those, if one doesn’t already exist!
Leave a Reply to walterCancel reply
