The (UV) Writing’s On The Wall
[Michael Karliner]’s Belshazzar, named for the Biblical character upon whose wall the writing appeared, is a unique light painting machine, that tracks an array of UV LEDs across a glow-in-the-dark background to paint transient dot-matrix letters in light. It was one of many cyberpunk-themed art pieces in Null Sector at the 2018 Electromagnetic Field hacker camp this summer.
The row of LEDs hangs down from a carriage that traverses a tubular rail, and is edged forward by means of a stepper motor driving a roller. This arrangement delivers the benefit that it can be scaled for displays of any length. The LEDs are driven from an Arduino via a Texas Instruments TLC5940 PWM driver ship.The result can be seen in the video below the break, and those who saw it at EMF may remember it tracing suitably dystopian phrases.
15 thoughts on “The (UV) Writing’s On The Wall
  1. An interesting area to explore for longer target material light emission could be the conjunction of formulation and fabrication methods, such as adding variety of secondary fluorescence chemicals (spectral cascade issue with implicit colour change) and mix of range of sizes of crystalline nano particles as well as overall thickness of course Eg for longer light path length and maybe even some lithium niobate type dopants, given that material’s strange properties…
    1. I’d love to hear more on yourideas for material improvements. Actually, a real issue was the persistence being too long, as the next message started being written before the last was fully gone. A later version of Belshazzar ran on powered tracks and was designed to run around long continuous tracks to obviate this problem, but proved too unwieldy and unreliable for installation.
      1. If you flash the image on quickly it all fades down pretty evenly. I’m not positive on the persistence curve of that material, but I think it was rated to glow for a long time.
        For that one I used the glow sheet that sparkfun used to sell. But I have since found that there are some nice glow vinyls available in large sheets ( 5′ x 5′ for automotive wrapping applications) on amazon (kinda expensive though)!
  2. Actually, this is the original version (1) of Belshazzar. The one at emf (version 4) was re-engineered to be able to run for three days solid reliably. It also used an on board Raspberry Pi to do the rasterisations and had an MQTT connection to take new messages. Version 2 of Belshazzar used a UV laser to do vector drawings and version 3 (failed) ran wirelessly on powered tracks so it could go round and round a continuous track and leave continuous messages behind it.
Leave a Reply to mkarlinerCancel reply
