Dexterity Hand Is A Configurable Prosthetic Hand
One of the interesting benefits of the 3D printing revolution is the dramatic increase in availability of prosthetics for people with virtually any need. With a little bit of research, a 3D printer, and some trial and error, virtually anyone can build a prototype prosthetic to fit them specifically rather than spend thousands of dollars for one from a medical professional. [Dominick Scalise] is attempting to flesh out this idea with a prosthetic hand that he hopes will be a useful prosthetic in itself, but also a platform for others to build on or take ideas from.
His hand is explained in great detail in a series of videos on YouTube. The idea that sets this prosthetic apart from others, however, is its impressive configurability while not relying on servos or other electronics to control the device. The wearer would use their other hand to set the dexterity hand up for whatever task they need to perform, and then perform that task. Its versatility is thanks to a unique style of locks and tensioners which allow the hand to be positioned in various ways, and then squeezed to operate the hand. It seems like a skilled user can configure the hand rapidly, although they must have a way to squeeze the hand to operate it, or someone will need to develop an interface of some sort for people without needing to squeeze it.
To that end, the files for making your own hand are available on Thingiverse. [Dominick] hopes that his project will spark some collaboration and development, using this hand as a basis for building other low-cost 3D printed prosthetics. There are many good ideas from this project that could translate well into other areas of prosthetics, and putting it all out there will hopefully spur more growth in this area. We’ve already seen similar-looking hands that have different methods of actuation, and both projects could benefit from sharing ideas with each other.
Thanks to [mmemetea] for the tip!
https://www.youtube.com/watch?v=cHdmQVxIYNo
5 thoughts on “Dexterity Hand Is A Configurable Prosthetic Hand
  1. I suspect that the intention is to have a cable operated by some other body part. I have seen a metal-hook style prosthetic that was operated by a cable round the users back. Pulling shoulders forward pulled the cable and opened the hook, relaxing back allowed it to spring closed.
    This hand looks like it should be operable by the same method.
Leave a Reply to Dominick ScaliseCancel reply
