Robotic Cheetah Teaches A Motors Class
It seems like modern roboticists have decided to have a competition to see which group can develop the most terrifying robot ever invented. As of this writing the leading candidate seems to be the robot that can fuel itself by “eating” organic matter. We can only hope that the engineers involved will decide not to flesh that one out completely. Anyway, if we can get past the horrifying and/or uncanny valley-type situations we find ourselves in when looking at these robots, it turns out they have a lot to teach us about the theories behind a lot of complicated electric motors.
This research paper (gigantic PDF warning) focuses on the construction methods behind MIT’s cheetah robot. It has twelve degrees of freedom and uses a number of exceptionally low-cost modular actuators as motors to control its four legs. Compared to other robots of this type, this helps them jump a major hurdle of cost while still retaining an impressive amount of mobility and control. They were able to integrate a brushless motor, a smart ESC system with feedback, and a planetary gearbox all into the motor itself. That alone is worth the price of admission!
The details on how they did it are well-documented in the 102-page academic document and the source code is available on GitHub if you need a motor like this for any other sort of project, but if you’re here just for the cheetah doing backflips you can also keep up with the build progress at the project’s blog page. We also featured this build earlier in its history as well.
14 thoughts on “Robotic Cheetah Teaches A Motors Class
  1. At some point they’re going to have to lose the tether though… the question is, can they pull it off?
  2. “the leading candidate seems to be the robot that can fuel itself by “eating” organic matter. We can only hope that the engineers involved will decide not to flesh that one out completely. ”
    eating…flesh…
    Well played sir!
  3. I long for the day when we can make a walking platform for under $500. It is the last piece needed for a functional bot.
        1. I think [old fart] meant construction cost/BOM, not tooling and TCO, which certainly puts procreation at a high advantage.
          Don’t even get me started on ROI, for either of them.
  4. I want one of those hip joint assemblies.
    I want to have all three motors mounted like that. This asembly looks like one of the coolest things I have seen in a while.
    1. Can you imagine old fogies have hip replacements like that.
      Seeing all the old fogies bouncing down the road would be so so scary.
Leave a Reply to OldFartCancel reply
