100 Year Old Atomic Clock
Precision time is ubiquitous today thanks to GPS and WWVB. Even your Macbook or smartphone displays time which is synchronized to the NIST-F1 clock, a cesium fountain atomic clock (aka the ‘Atomic Clock’) that is part of a global consortium of atomic clocks known as Coordinated Universal Time (UTC). Without precise timing there would be train collisions, markets would tumble, schools would not start on time, and planes would fall out of the sky.
But how was precision timing achieved in the 19th century during the era of steam, brass, and solenoids? One of the first systems of precision timing kept trains running safely and on time, rang the bells at school, and kept markets trading by using a special clock designed by the Self Winding Clock Company. Through measurements of celestial objects by the US Naval Observatory, and time synchronization pulses broadcast by the Western Union telegraph network, this system synchronized time across the United States in an era where the speed of our train system was out-pacing by the precision of our clocks.
Those clocks were designed so well that many of them are still around and functioning. One of these 100-year-old self-winding clocks made its way onto my workbench. I did what any curious hacker would do, figured out how the synchronization worked and connected it to a clock source with atomic precision. Let’s take a look!
Clock Synchronization That Was Ahead of Its Time
Self Winding Clock Company, Grand Tower Clock, displayed at the Palace of Liberal Arts at the 1893 Columbian Exposition, image from Scientific American, July 29, 1893.
The world changed at the 1893 Columbian Exposition; electricity came of age, tens of thousands of lightbulbs adorned buildings, AC won the battle of the currents, and a system of precisely synchronizing clocks across the entire United States was introduced by the Self Winding Clock Company.
Day-to-day precise timing was provided by the US Naval Observatory in Washington DC who would measure the solar transit of either Mercury or Venus to synchronize the observatory master clock (there were three of them to check the others). This served as the master clock of the entire United States. This official time was transmitted to Western Union for re-transmission via the Western Union network to the regional and local offices.
A time synchronization pulse would be transmitted from the local Western Union office once per hour at the ‘top of the hour’ to customers who were subscribed to the synchronization service. Each customer would pay $1.25 per month per self-winding clock — some subscribers would only synchronize one clock but there were also entire buildings, offices, factories, schools, and train stations connected to the service.
The block diagram below shows a master clock receiving synchronization signals from Western Union. With precise timing, the master clock controls a plurality of secondary clocks.
Secondary clocks were electronic repeaters that would simply repeat the time indicated on the master clock using electromagnetic solenoids, updating the time displayed on their clock faces every 30 seconds. Any number of secondary clocks could be used in large scale installations. This clock system and its precision timing service was very popular. Shown below are many prominent examples of Self-Winding-Clock installations as of 1908.
You’ve Probably Seen These Self-Winding Clocks
Although the Western Union time service ended in the 1960’s, Self Winding clocks are still in operation all over the country, including several at Grand Central in NYC:
Similar in appearance to the oak cased clock at Grand Central, I was fortunate enough to be given a Self Winding Clock by a friend of mine Josh Levine. Another friend of mine, Larry McGlynn, helped me to date the movement to between 1910 and 1930 based on its serial number. So I consider this to be a 100 -year-old clock.
Usually I expect to spend some serious repair time when I acquire an old clock. This means disassembling, cleaning, oiling, and re-assembling the entire movement to get it working like new. I was lucky here because Josh had already serviced the movement and it was running strong. But after starting the movement it died within the hour. That was weird, usually pendulum wall clocks last for 8 days on a wind and I’d certainly expect it to go for more than an hour after such a strong start.
It turns out that this was a feature not a bug. I learned that the main spring barrel for this clock movement could only support 1 hour of output before the clock would stop. It self-winds using battery power and it deliberately only puts one hours worth of tension into the mainspring to maintain a consistent torque on the gear train for the purpose of maintaining accuracy and minimizing wear on the pivots. It runs for just one hour on a wind.
How Self-Winding Clocks Work
Here is how it works; the clock winds up and runs for about an hour. After an hour a cam closes a circuit and turns on the self-winding motor which winds the main spring until another cam shuts off the motor. The winding tension is good for about 1 hour then the entire process starts over again.
This is not a spinning motor with brushes and a stator. Instead, it is a pair of solenoids that pulls a lever arm with a paw gear which pushes a gear wheel. As soon as the lever arm is raised by the solenoids the electrical connection to the solenoids is broken, causing the lever arm to immediately fall back down again. This action repeats itself over and over again in a jack-hammer-like motion winding the main spring until the switch on the mainspring stops the motor. Chug chug chug!
Using a pair of 1.5V dry cells in series this clock will operate for at least 1 year before the batteries die. Interestingly enough, modern D-cells are functionally equivalent to the old dry cells, so expect 1 year of operation out of a pair of D cells.
The engineers of this clock movement could have used a DC motor with brushes but they choose this motor. I can only guess that a decision was made to use this motor architecture for long-term reliability. I can tell you that my motor still works reliably at 100 years old. By contrast, I’ve found that even mil-spec brushed DC motors from 75 years ago require a great deal of care to make them spin again.
Synchronization a 100-Year-Old Clock with GPS
For a while I was subscribed to Hackerboxes to force myself to learn how to use Ardunio and other easy-to-use embedded controllers. One of the projects was called ‘Clockwork’ and included a GPS module. I wrote a simple sketch feeding GPS time to the 7 segment display and put all of that together into a nice project box resulting in this Arduino-controlled GPS clock which covers two time zones and displays GMT.
This Arduino-GPS clock came in handy for controlling my 100-year-old Self Winding Clock synchronization solenoid. To synchronize the Self-Widing Clock I added a relay board and wrote a sketch to emulate the Western Union time protocol, thereby making the big clock synchronized to GPS. The protocol is simple, and well-described in this video by J. Alan Bloore. At the top of the hour a three-volt pulse is sent to the synchronization solenoid for less than one second. The synchronization solenoid then pulls the minute hand straight up to the 12 o’clock position.
I choose to use a 5V pulse to give it extra torque and decided to leave the pulse on for 500 mS. I put together a video overview of this entire project. If you’d like to jump to the demo of my clock synchronizing itself to GPS, start about fourteen minutes into the video.
After Nearly 1 Year of Operation
Every hour there’s a chugging noise that kind of sounds like a sewing machine, this is the self-winding action. At the top of every hour there is a loud and satisfying clunk-clunk which is the synchronization solenoid pulling the minute hand into position. If I leave my R390A comm receiver tuned to 10 MHz then the clunk-clunk happens at precisely the same time as the long beep transmitted from WWV at the top of the hour. All of this makes for an impressive horology demo for our house guests.
This clock was put back into continuous service just before new years 2018 and continues to give reliable and accurate service to this day without incident. Not only does it serve as the shop clock, I also use it to synchronize my various other clocks and watches that I tinker with.
I’d love to hear from those of you that have your own self-winding clocks in the comments below. And if you are interested in precision timing in general then I suggest joining the Time Nuts email list. From here you will receive numerous email discussions about precisely measuring time, oscillator frequencies, oscillator drift, phase noise, and many other topics.
33 thoughts on “100 Year Old Atomic Clock
      1. There is a Firmware fix for that widening waist.
        The patch works well, and requires a mod to fuel downloads, and a performance boost. Keep in mind waste heat will increase and some modification to the fuel download will have to be carried out periodically in order to maintain sufficient mass reduction.
        Forty-Nine Kilos and still shedding mass.
        This human-type biological system also has a self-winding feature, to maintain, and modulate energy usage.
  1. Great work, fun old clocks. Two D cells wind mine for about thirty months. I was able to keep it set precisely by subverting the alarm on an ‘atomic’ travel clock but the battery life was not good. A crystal oscillator currently keeps it within half a minute a year. I have not been able to get the mechanical movement itself to run better than a few seconds a day.
  2. Yes but take a wild guess as to who made the abundant clocks used in schools all over the country during that time period? Okay since all of you will mist it, it is the ITR, International Time Recording company. One part of what is now called IBM. They were all arranged in similar fashion, with a centralized controlling clock in the offices of the school.
    1. The clocks in my high school had no movement inside the clock itself that kept time, every minute a pulse from the master clock would advance the minute hand. There must have been multiple pulses though since the clock would click and the minute hand would move slightly backwards, and then on the minute it’d CLUNK and the minute hand would move forward. When the clocks would go back an hour in the fall, the clocks would get driven at like 10 times the normal speed to advance it all the way around to the previous hour, since the clocks could not move backwards, so the Monday after the time change none of the clocks were correct. Senior year they upgraded a bunch of the equipment (the school was built in the 50s and IIRC the clocks were original) and although the clocks remained, instead of the normal bells someone got the wild idea to replace the bells with tones through the intercom system, with the bells becoming the fire alarm. I don’t remember what brand they were but would seem to me that this type of clock might be easier to get ahold of and drive with an Arduino or something.
      1. Or a ratchet mechanism, where giving high signal to solenoid would move back arm, then releasing it exactly at minute mark would advance gear connected to minute arm.
      2. Yes, these clocks are extremely easy to drive with an Arduino. i have an old 1960s Simplex clock that works exactly as you described. It just needs a 24ish volt pulse every minute to work. So I have a DS3231 RTC triggering an interrupt once per minute on an ATTINY that then pulses the clock with a MOSFET. Everything is powered with 16 AA batteries and crammed in the empty space behind the clock face, and should last about 4 years according to my napkin math. Only problem is the loud KA-CHUNK sound every minute!
  3. > in an era where the speed of our train system was out-pacing by the precision of our clocks.
    … was out-paced by the precision of out clocks.
  4. I seem to recall the clock in one of my older (mid ’70s) SAAB’s used a similar self winding mechanism. A solenoid would be triggered periodically to wind the spring and keep the clock ticking.
    UnfortunatleyI no longer have one to pull apart any more
    1. I was going to say that fifty years ago I saw some articles about using clocks from cars indoors. They used a similar arrangement, and as scrap were available cheap.
      Michael
      1. I’m guessing using an automotive clock in a house may increase its accuracy as the house would offers more consistent temperature than a car.
    2. This type of automotive clock was widespread. The ones I looked closely at were from a 1958 Buick and a 1966 Corvette. The spring was good to run the clock for about 30 seconds. At the end of that time, contacts closed and a solenoid jerked the spring back to fully wound for another 30 second run. They weren’t very reliable and generally failed after a few years, although disassembly and reassembly was usually enough to get it running again.
    3. That was really the only good way to have an accurate car clock prior to crystal oscillator driven clocks becoming common. In most cases, they still weren’t very accurate. I have heard that some models would adjust the clock to run a little slower or faster, depending on which way it was moved when set, in an attempt to tune the clock rate. That made crossing time zones or DST interesting…
  5. I have a Standard Electric Slave clock from my school days. It uses a single solenoid to pulse one minute intervals. It was powered by a 24 volt line from a master clock in the principal’s office. I operate it from a PIC controller that provides the minute pulses.
    For an interesting time piece look at the British Synchronome. It was a pendulum clock that used an 18 pound artillary shell for its weight. It was combined with a separate free pendulum movement in a vacuum case to make the Shortt-Synchronome clock. This was the astronomical time standard before the advent of crystal oscillator based time pieces.
  6. If $1.25 in 1919 adjusted for inflation = $18.54
    And 720 bytes = .000000090 Gb
    ~$206M /Gb
    …Is one way to my data plan look downright reasonable.
  7. Cyril Kornbluth the SF writer wrote a novel called “Not This August”, where the time pulse distributing network was used for a covert communication system by the Resistance. It’s a good read.
  8. A lot of clocks are designed to run dry as oil and grease will attract dust and accelerate wear while the forces on the parts are minor. Don’t oil clocks because they’ve got gears. Be sure the one you have actually needs oil or grease as it may not.
  9. NICE ! I have two of the old SWCC clock’s used by Western Union ions ago, One is encased in a BEAUTIFUL, solid oak wooden enclosure and the other, later model is the classic metal, round type of WU clock. I have them both running perfectly although I have not taken that extra ‘leap’ to actually set them up to monitor a sync pulse.
    I too, had both, several old military R-390A’s as well as an old R-392 receiver. GREAT old sets ! I wish I still had one of each of them, sadly, I do not..
    GREAT job, GREAT topic ! 73 ! Mark, WN3SIX
  10. Ingenious and fun as well as accurate! I have some work and interest in time synchronization protocols (IEEE 1588, Synchronous Ethernet etc) and this was nice to read :-)
    1. For some reason unknown to me, clocks and watches are fascinating devices. It’s unbelievable to know that clocks are virtually everywhere!!!! Due to the invention of commerce, transportation and many ways of communication, it’s pretty much no wonder to me that we have the precision that we have nowadays. I love clocks, watches, timers, chiming clocks (Such as Big Ben, and The Gastown steam clock that plays the Westminster chimes on steam pipes) and automaton clocks, such as the Prague astronomical clock. My phone has one of the themes used in the classic Gameboy game ‘Tetris’, and I use it as my main ringtone on my phone, as well as my “time has expired” alert for my timers on my phone, and I even use it as my alarm on my phone. Do any of you live in a town that has outdoor warning sirens? It’s likely that you do, and if you do, does it go off at a certain time during the day or something like the “Second Tuesday of the month at 10 AM”? It’s an audible time signal. (Sorry for giving you guys ‘TMI’, but I can’t help the fact that clocks and watches are my kind of thing, in addition to some other things) Sure, they’re used to warn of Tornadoes and such, but they are also used in some cities to warn volunteer firefighters of an emergency.
  11. I don’t know if this site is still active or not BUT,
    I started fooling with SWCC clocks years ago as a hobby; still do. The very first thing I wanted to do is use WWV to sync my clocks but never did. I got lazy and used a crystal oscillator instead. However, I’m still planning on doing it at some point. Not being familiar with Arduino and code etc, I’m looking for an easier way out by using an old GPS to ultimately drive a relay as you did. Ultimately I’ll mount the device maybe in the attic and run wires to all my clocks that have sync coils. I have a SWCC master that didn’t use Sync coils and It is so accurate (within a second or two a month (all temperature related) that I decided I’d leave it as is.
    What I’m really writing about is this: It seems we both have an admiration for these Self Winding Clocks and I might add, R390’s and other related electronics particularly those of old! I am really finicky about precision and to be able to make these 100 year old pendulum clocks (which are very accurate even before being synchronization) more accurate then most any other mechanical clocks is just awesome.
    Having said that, I don’t know how you can stand having that minute hand mechanical inaccuracy. I’ve had that problem and it drove me crazy. What I found on all my minute hands is that the bushing that the hand is mounted on can be adjusted. Some are tighter then others but while using some basic techniques and common sense precautions, you can hold the hand and turn the bushing the amount needed to put that minute hand dead on. You did a great job of using the National Bureau of Standard’s atomic clock (WWV) so fixing that minute hand problem would be a must for me!
    Great Job!
    Larry
Leave a Reply to Nathan Diniz (@clockdude2010)Cancel reply
