Atari Tape Drive Turned Security DVR
We know that a lot of our beloved readers don’t take kindly to abuse of vintage hardware, so the Atari fans in the audience may want to avert their eyes for this one. Especially if they’re particularly keen on spinning up their Jawbreaker cassette on authentic hardware, as [iot4c] has gutted an Atari XC12 Program Recorder to turn it into an enclosure for a Raspberry Pi video storage device.
Step one of this conversion was, as you might expect, removing all the original hardware from the cassette recorder case. From there, [iot4c] fitted the Raspberry Pi, a USB hard drive, and a YDS-5A DC-DC converter to power them. Depending on what the drive setup looks like, it might also make sense to add a USB powered hub. A length of Ethernet cable was left hanging out the back of the Atari XC12 so it could be plugged into the network, but a panel mount RJ45 connector could spruce things up a bit.
Of course, gutting an old piece of hardware and sticking a Pi into it isn’t exactly breaking any new ground at this point. But we did appreciate that [iot4c] went the extra mile to wire it up so the “Save” LED now doubles as a network activity indicator. Which pretty much brings it full circle in terms of functionality for a network-attached video recorder.
Earlier in the year [iot4c] converted a 65XE into a USB keyboard with the help of an Arduino Leonardo, but the vintage Atari aficionados will be happy to note that at least in that case the donor machine remained fully functional.
11 thoughts on “Atari Tape Drive Turned Security DVR
  1. But is gutting a steel enclosure and re-gutting really a hack? Let me propose (and I am admittedly not capable of this) Using a deep learning neural network, w/ the camera input. AI sees a face not recognized as “Friend”, and pipes image to a FPGA, wich then does the dirty work of saving the image of the stranger’s face to the original hardware. IMO, repurposing vintage is way more “street cred” than just jamming new stuff into an old box…
    P.S. Not a hack?
      1. or: “blinking led defeats the purpose of this hack”. A nice hack anyway. I once put the internals of a Apple quadra 660av in a old binder to sit on the shelf. only the very loud dying HD made it very obvious that there was a computer in there… reverse hack, same problem
      1. Older version was made for commodore, the one for atari was identical – except for plug and pcb.
        ps. the one for Atari was available in two or three different color schemes.
  2. IMO the hack is outside the box…
    … because from the outside it looks like something low tech enough not to bother taking in a burglary, hence you are more likely to retain video of the perpetrators.
  3. Somebody has to upload a library of 3D printer “classic” cases so people can print new ones out instead of gutting old hardware.
Leave a Reply to I_Think_StuffCancel reply
