Hackaday Podcast 053: 1-Bit Computer Is A Family Affair, This Displays Is Actually Fabulous, And This Hoverboard Is A Drill Press
Hackaday editors Mike Szczys and Elliot Williams navigate the crowded streets of the hackersphere for the most interesting hardware projects seen in the past week. Forget flip-dot displays, you need to build yourself a sequin display that uses a robot finger and sequin-covered fabric to send a message. You can do a lot (and learn a lot) with a 1-bit computer called the WDR-1. It’s never been easier to turn a USB port into an embedded systems dev kit by using these FTDI and Bluepill tricks. And there’s a Soyuz hardware teardown you don’t want to miss.
Take a look at the links below if you want to follow along, and as always tell us what you think about this episode in the comments!
Take a look at the links below if you want to follow along, and as always, tell us what you think about this episode in the comments!
Direct download (60 MB or so.)
Episode 053 Show Notes:
New This Week:
Interesting Hacks of the Week:
Quick Hacks:
Can’t-Miss Articles:
3 thoughts on “Hackaday Podcast 053: 1-Bit Computer Is A Family Affair, This Displays Is Actually Fabulous, And This Hoverboard Is A Drill Press
  1. I picked this nickname back in 1994 when I needed login for mIRC:
    http://www.zoobab.com/whois-zoobab
    Dirtyjtag came from the frustration of not having versaloon firmware not working.
    There is also another japanese firmware named armblaster, I finally got an STBee board from a friend in Japan, it needs to be adapted to the bluepill, and it supports OpenOCD as well:
    https://github.com/zoobab/armblaster
    What is also needed is to modify OpenOCD so use libgpiod since linux v4.8, right night it only supports the Rpi gpios.
Leave a Reply to Ian FarquharCancel reply
