The Most Expensive D20 You’ll See Today
Roll your negotiation skill, because this d20 is a hefty one. The Tweet is also below. We are charmed by [Greg Davill]’s twenty-sided LED contraption, but what do we call it? Is it a device? A sculpture? A die? Even though “d20” is right on his custom controller PCB, we don’t think this will grace the table at the next elf campaign since it is rather like taking a Rolls Royce to the grocery store. Our builder estimates the price tag at $350 USD and that includes twenty custom PCB light panels with their components, a controller board, one battery pack, and the 3D printed chassis that has to friction-fit the light faces.
Power and communication for all the panels rely on twenty ribbon cables daisy-chained throughout the printed scaffolding, which you can see in the picture above. [Greg] made a six-sided LED cube last year, and there are more details for it, but we suspect he learned his lesson about soldering thousands of lights by hand. There are one-hundred-twenty LEDs per panel, times twenty, that is over two-thousand blinkenlights. We don’t yet have specs on the controller, but last time he used a SAMD51 processor to support over three-thousand lights. We don’t know where he’ll go next, but we’re game if he wants to make a chandelier for Hackaday’s secret underground lair.
(Editor’s Note: If you were at Supercon last year, and you got to play with this thing in the flesh, it’s worth it!)
Thank you for the tip, [cyberlass].
13 thoughts on “The Most Expensive D20 You’ll See Today
  1. $150 for what looks like an SLS printed part seems a bit steep. Of course, if you wanted to do a small run you could fill an SLS build and the piece price would go way down. Either way, very clean build and a neat project!
  2. I might be wrong but how is that 3D print worth $100? Unless he got this professionally printed and had to pay for shipping and super expensive filament.
  3. Not really a D20.. And I don’t think its LED count is quite high enough to really give it numbers.. A very pretty object though.
