Playing the tiniest of violins may be a phrase to encapsulate the complete lack of sympathy as someone unpleasant receives their just deserts, but have any of you ever considered how such a feat might be achieved? Unless you’re an unusually talented virtuoso with the bow, it’s difficult to believe that such a small instrument could be played with ease, even if it were to be available in the first place.
Happily a solution is at hand to all those minuscule stringed instrument woes, courtesy of [Alexandra Covor], who has created a miniature PCB violin that is after a fashion playable. It may not be a conventional instrument with a horsehair bow and traditional sounding mechanism, but its electronic voice should still deliver enough to delight.
At the heart of the violin-shaped PCB is an ATtiny85 and a piezoelectric buzzer, and just where you might expect them are a set of strings made from wire attached to the PCB. The instrument can play stored tunes, but since the strings are hooked up to an analogue input on the microcontroller, it can be played as a touch instrument. Finally a pair of LEDs behind the translucent FR4-only F-holes complete the look. It’s fair to say that Itzhak Perlman and his ilk are safe from challengers bearing this instrument, but it’s still an eye-catching piece of PCB art.
This isn’t the first tiny violin that’s been featured here, some others are much smaller.
It’s nice work. These can be a lot of fun to pull out of a cup on your desk. I have one of the TinyCircuits PCB violins from a while back. These tiny violins do make people smile so much more than other tiny-sized hacks.
Four strings
Across the bridge
“At the heart of the violin-shaped PCB is an ATtiny85 and …”
So why isn’t it tagged with Attiny85?
TinyCircuits also made a tiny violin about this size a while back.
https://tinycircuits.com/products/tiny-violin
