Nintendo Zapper Reborn As Home Automation Remote
Generally, using a gun to turn your lights off is dangerous and expensive, but for the [DuctTape Mechanic], it’s just how he does things. Video also after the break. To be fair, he uses a salvaged Nintendo Zapper, not a firearm, and replaces the guts with an RF transmitter. We are shocked that he chose a radio model instead of infrared seeing as how he is repurposing a light gun, but our scores in Duck Hunt suggest he made the right choice.
The transmitter comes from a keychain remote, so it all fits neatly inside the Zapper chassis. A couple of wires hijack the stock button and run to the stock trigger, so you keep that authentic feel. The receiver side is a bit trickier. When it senses a button press, it sends a pulse, as you would find in a garage door opener, but to keep a lamp on, there needs to be some latching and so there is an Arduino. The microcontroller keeps a tally and operates a 10 amp relay module, so it is mostly acting as the glue between hardware. All of the mains electrical components sit in a blue plastic box with a receptacle on the front.
We don’t see the Zappers used for their intended purposes much anymore because they rely on old technology, but that doesn’t keep people from repurposing the iconic peripheral.
3 thoughts on “Nintendo Zapper Reborn As Home Automation Remote
Leave a Reply to JohnCancel reply
