Audio Tape Interface Revives Microcassettes As Storage Medium
An Arduino Nano connected to a portable tape recorder
In the early 1980s cassette tapes were the standard storage medium for home computer users; readers of a certain age will remember fiddling with audio jacks, tape counters and signal levels, then waiting for several minutes while a program (hopefully) loaded correctly. While most people happily upgraded to much more reliable floppy disks, [Zack Nelson] decided to go back in time and add a suitably classic storage medium to a retrocomputing project, in the form of a cassette interface. The cassette player he had available was a Pearlcorder L400, which uses the smaller microcassette instead of the familiar audio tapes used in your Walkman or boombox.
A microcassette and a computer interface for a tape recorder[Zack] designed the entire thing from the ground up: first he decided to use differential Manchester encoding,  which provides immunity against common disturbances like speed variations (which cause wow and flutter). The data is encoded in the frequency range from 1 kHz to 2 kHz, which suits the bandwidth of the cassette player. Next, he designed the interface between the computer and the tape recorder; built from an op-amp and a comparator with a handful of discrete components, it filters the incoming signal and clips it to provide a clean digital signal to be read out directly by the computer.
The system is demonstrated by hooking it up to an Arduino Nano, which reads out the data stream at about 3000 baud. The noise it makes should bring back memories to anyone brought up with the “PRESS PLAY ON TAPE” message; if it inspires you to make your own, we’re happy to report that full schematics and source code are available. [Zack] is not the first one to make his own cassette interface; we’ve seen a somewhat more complicated analog design before, as well as one based on an FPGA.
37 thoughts on “Audio Tape Interface Revives Microcassettes As Storage Medium
  1. I don’t understand. Why do people want to re-invent the 80s? Sure, it was a time of great change. But the changes were all transitional, and things got even better, LATER.
    1. It’s the last time people could realistically understand modern technology right down to the silicon. And what’s out there today is built on the bones of what was around back then, so understanding *this* gives you skills to help you understand *that*.
      Also, people enjoy playing with stuff. Why be such a party pooper about it?
    2. The reason why people is always reinventing the wheel is to learn things along the process.
      That should not be a surprise as it is exactly the same method used in schools, repeating the same steps, doing the same math for centuries.
    3. I have a few audio tapes lying around still from the early 90s. It’s probably been a year or two since I tried to play one. When I did it played just fine.
      For the obvious reason I don’t have any SD cards or USB sticks that old to try the same test. But I’ve certainly had plenty of them that failed on me.
      This is probably not a viable way to archive hours of hd video but it might be a good way to back up one’s own source code projects. It very well may outlast your favorite cloud backup service company and you don’t even have to trust a stranger on the internet with your stuff.
      Who knows, maybe some years after you kick the bucket maybe your kids will appreciate the opportunity to see what you were up to.
    4. To add to the rest of the comments, another reason could be a “security by obscurity” frame of mind, in that all of my stuff is backed up on this cassette tape, and without the proper understanding or hardware you’re not getting to it.
      Besides that, the 80s were RAD, man!
    5. ‘We must welcome the future, remembering that soon it will be the past; and we must respect the past, remembering that it was once all that was humanly possible.’ -George Santayana
  2. I use a Tascam 688 and 424 Mkii for some projects. This is really cool! However, a few months ago I read up on SMPTE syncing my tapes to my DAW. So now instead of being limited to only 4 or 8 cassette tracks, I can have “infinite” tracks with SMPTE.
    https://youtu.be/ucDJohgSrSM
    1. 3,000 baud is 2,400 bits/s without the framing. That’s 300 Bytes/s. 1,800 seconds in a 30 min cassette gives 540KB.
      So, this technique might get a full MB on a 60 minute tape. :)
    2. But remember, when we used cassettes, programs were small since memory was small.
      I wouldn’t want to wait 30 minutes for a program to load
      But I never did any “serious” work until 1984 and my first floppy drive. So I was just loading programs, not data. I actually bought some ten minute cassettes meant for outgoing messages on answering machines. Better to have multille cassettes than spend time trying to find a specific program on a 60 minute tape full of programs.
      I never went back to cassettes after that floppy drive in 1984. They were fine until I got something better, at which point the past was in the past
  3. Now I’m wondering how much data could you actually squeeze onto a actual 60 minute tape ?
    In the 70’s and 80’s the data on the tape were typically:
    FSK (Frequency-shift keying) modulation e.g. Kansas City standard
    Differential Manchester Encoding e.g. ZX Spectrum’s and Sinclair QL’s microdrives
    PSK (phase shift keying) modulation e.g. Vector-06C
    PWM (Pulse Width Modulation) e.g. Commodore Datasette
    If you used something like 64 QAM and just for fun some modern forward error correction (FEC) with low-density parity check (LDPC).
    1. One resson many cassette interfaces were slow is to accomodate off the shelf cassette recorders. Limited bandwidth, AGC, no level control on record. They weren’t a great choice, they were cheap and available.
      There were some projects that modified the machines. Use them as a transport, but directly connect to the tape head. So DC into the tape head for saturation recording,and comparators on the tape head for playback.
      1. The Braemar CM600 is an example of a commercial cassette drive that did those tricks stock. It used a proprietary format very similar to microcassette too.
      2. The Braemar CM600 is an example of a commercial cassette drive that did those tricks stock. It used a proprietary format very similar to microcassette too. It only gets to 2400 baud, but that might be at a slow tape speed.
    2. The amount of data you can transmit is basically the bandwidth you have times the headroom for your signal.
      In this case, the noise floor is about -32 dB and the good bandwidth goes from about 1000 to 4000 Hz, so the channel capacity should be (Shannon capacity) about 32 100 bits per second. Approximately 13.8 Megabytes per 60 minute cassette.
  4. It would be interesting to see if you could turn the audio microcassette into Digital videotape, as I think you could. Push the audio bandwidth to 8 kHz, use 64 QAM and you could get 64 kbps, just enough for mp4 video at resolution 160 x 120 !
    1. Sounds like 64 QAM won’t work with all the tape noise. I’m curious if any variant can handle the speed fluctuations.
      I’m not sure you can get 8kHz bandwidth either. Maybe with the rare Type IV microcassettes, and a suitable recorder.
    2. Cassettes’ flutter (similar to jitter, and depends mostly on the machine) and dropouts (which depends partly on the machine’s tape handling but mostly on the tape itself) impose limitations you don’t get with telephone lines or even radio.  The phone modem constellations of amplitude and phase modulation that allow 56kbps on a phone connection whose frequency response is limited to a few kHz are not useful without a solid, clean transmission medium with good S/N ratio, no significant jitter (since it really fouls up the phase), etc..
      I worked as a repair tech on semi-professional-quality tape recorders at TEAC in the early 1980’s.  While all the frequency response specifications went up to the 12kHz to 24kHz range, the open-reel machines were measured at 0VU and the cassettes were measured at -40VU.  The cassettes’ upper frequency response limits were only about 3-4kHz when measured at 0VU!  The exception was the Portastudios, which used an exceptionally low 60kHz bias frequency and ran the tape twice as fast.  Watching the oscilloscope play back a steady tone of a few kHz recorded on most cassettes was pathetic It definitely was not a solid, steady tone with a motionless display on the ‘scope!  A dropout may only last a couple of ms, but could be severe at a few kHz.  And if you put a square wave in (at lower frequencies), someone just walking up to the workbench would never guess from the output waveform that you actually started with a square wave.  The open-reel machines did much better.
      When you align a tape recorder, one of the first things you do is put a on calibration tape and adjust the azimuth of the playback head for maximum output.  You start with the lower frequencies and go to higher ones.  If you get the idea to really fine-tune it by using two different tracks and looking at a Lissajous figure on the oscilloscope, you’ll find that at higher frequencies the phases between the two tracks of a cassette make a disastrous Lissajous pattern that more closely resembles a swarm of bees than a nice diagonal line.  This is particularly true if the tracks are very far apart instead of being next to each other.  The calibration tape itself has a single track that goes across the entire width of the tape, so the phase variations come from the fact that the tape is not perfectly rigid and the tape recorder does not pull it across the head perfectly evenly.  Instead, there are what I might call microscopic turbulences (for lack of a better term) in the way the tape “flows” over the head.  The flutter is not even consistent from track to track, meaning you can’t use the right channel as a phase reference for the left channel, because it’s like the tape’s angle across the head continually changes.  (Note that the left channel is on the edge of the tape, so it is more susceptible to the various problems also.)  It all works much better on open-reel machines, for several reasons.
      Microcassettes will of course be even worse than the CompactCassette which used to be ubiquitous.  A partial solution for data would be to run the tape much faster.
      1. Hey Garth! You shared some of your expert knowledge with me on the 6502 forums years ago. Cool running into you here on my project; I didn’t know you had a background in audio too.
        Yeah, I love cassettes, but they’re a crude medium, especially in the world of computers. That’s the fun though! It’s still sort of magic that a tape deck can whisper in the ear of a computer and teach it a new trick. Have you supported tape drives on any of your 6502 builds?
        1. Zack Nelson, yes, we had a topic about it there, and I copied material from my posts there so I wouldn’t have to re-type it all.  Tape recorders give me a good feeling, like some people might get from carrying Grandpa’s pocket watch or pocket knife or having a restored classic car.  In fact, I’d sure like to have a Nagra or Stellavox professional portable open-reel machine; but I sure can’t justify the thousands of dollars they still go for when I can’t really say I have any use for one anymore.  I do have a use for microcassette machines that cannot be satisfied by any of the digital voice recorders I’ve seen; because in this use, I have to be able to operate it without looking at a display of any kind and going through menus and so on.  Partly for the fun of it though, I would also like to put data on microcassettes.  A problem with the tape machines, which does not involve the tape itself, is that virtually all of them have rubber belts or other rubber parts that rot.  I have found sources for most belts; but the microcassette machines in particular are made so compact that if you even can get belts that small, I don’t think I could get the thing open and replace the belt (and any other rubber wheels, even the pinch roller), and get it back together.
          I designed a tape modem and transport-control electronics for something for work nearly 40 years ago.  We used a transport that had no buttons on it, and could be controlled only electronically, and they were to cost us hardly over $6 each in quantity.  It had a stereo R/P head, and the plan was to put voice on the left channel and data on the right.  The amount of data was pretty light, only location information for the computer to find the right voice stuff, and times for when to play it.  There was also an optical sensor that watched the black and silver stripes go by on one of the reel tables, so the computer could have the tape counter information and get to approximately the right part of the tape to know when to slow down and start looking at the digital data for specific identifiers.  I didn’t know it at the time, but what I developed to put data on the tape, at 300bps, was pretty much exactly the same as the Kansas City Standard.  The modem I designed was made up of parts that all together would have come to about a dollar our cost.  The tape part of the project got cancelled before we finished though, so as fun as it was, I didn’t get to see it go to production.  I did however make a pretty much identical modem for myself to use at home.  Record and playback levels were almost irrelevant, unlike what I’ve read about others where if you didn’t set it just right, they wouldn’t work.  I thought cassettes would be around indefinitely.  Well, although cassettes’ run lasted for several decades, it did finally come to an end, and now I don’t have a working cassette machine anymore.  My favorite here has a mechanical problem, and the parts to fix it are no longer available.  My solution now for super compact digital storage for home projects, which is much simpler than SD Card, is the half-postage-stamp-sized I2C-6 EEPROM module and SPI-10 flash memory module shown on the front page of my site, with links to datasheets, at http://wilsonminesco.com/ .
          1. Ah, ok. I found your post now. I don’t remember it, but I very likely read it at some point.
            Yeah, I’ve been obsessed with Sony’s BM-600 microcassette recorder because it has an electronically (and remotely!) controlled transport. Virtually all of them die from a plastic gear that gets brittle, cracks, and seemingly can’t be replaced.
            That’s too bad that your modem didn’t go into production. I came up with a crude one that uses mostly schmitt triggers.
            https://zeninstruments.blogspot.com/2021/10/a-cmos-fsk-modem.html
            Oh, I like your little SPI modules. Much more practical.
          2. Zack Nelson, my apologies for the delays.  I have not been able to figure out how to make the email notifications work; so I have to keep a record of the URLs where I commented and come back periodically to see if someone has replied.  Whether I have the “Email me new comments” thing slid to the left or the right, makes no difference.  It doesn’t work.
            What I did to make it phase-continuous is to switch an extra resistor in and out, rather than an extra capacitor.  For the detector, it’s a flip-flop with the data input being from a Schmitt-trigger inverter whose input is from an RxC time constant that gets discharged once per cycle and the clock is from the carrier.  If the clock rises before the RxC has had time to charge up to the Schmitt-trigger threshold, it means it’s the higher frequency, otherwise it’s the lower frequency.  I amplified everything to clipping anyway, so levels didn’t matter.  This was to be used with a UART, meaning the tape speed had to have the corresponding accuracy.  It’s not a problem if you recorded and played on the same machine; otherwise you might have to pay a little attention to it.
  5. I was online via Packet-Radio on CB radio in Europe with a 1200 Baud PC COM modem.
    It used AFSK and was connected to the MIC in and SPK out of my CB radio.
    Computer was a 80386 PC/AT running MS-DOS and the TFPCX driver.
    Was online with that setup up to the mid 2000s.
    Some digipeaters (DIGIs) also had a 2400 Baud modem listening on a secondary channel.
    4800, 9600 Baud and up required FSK, sadly, which didn’t travel into the radio over audio cables.
    So this technology isn’t as obsolete as some louder voices here may think. ;)
    If the frequency range stays limited to less than 3KHz (regulations!), there’s little to improve without using imagination. .
    Other modulation techniques like QAM could be used, perhaps.
    1. I’m not sure Dolby is going to be helpful here. It uses companding, but we have no dynamics. The other trick it uses is lowering bass in order to boost highs (relative to the noise floor). We already have no bass, and the highs are at maximum volume.
      More aggressive bandpass filtering might make higher frequencies useable though. It depends how much noise is left in the pass band.
    2. No need to use Dolby, since that’s just a way of getting more apparent dynamic range out of audio. In this case, all you need to do is pre-emphasize the highs in recording, and maybe punch them up again on playback. But it’s still going to be limited by the head gap.
Leave a Reply to Twisty PlasticCancel reply
