Wii Meets Its End In Breadcrumb Jail
One of often encountered traits of a hacker is an ability to build devices into places where they don’t belong. Perhaps, [sonictimm]’s self-descriptive WiiinToaster was somewhat of an inevitability. Inspired by the legendary Nintoaster project which used a NES, this is a modern take on the concept, putting a Wii inside what used to be an ordinary bread-making kitchen appliance. [Sonictimm] has taken care to make it as functional while reusing the user interface options commonly found in a toaster, with some of the Wii’s connections routed to the original buttons and the lever. It’s compatible with everything that the Wii supports in its standard, non-toaster form – the only function that had to be sacrificed was the “making toast” part of it, but some would argue it’d be a bit counterproductive to leave in.
[Sonictimm] says it took five years from building the WiiinToaster to documenting it, which sounds about right for an average project. If you, like many, have a Wii laying around that you haven’t been using for years, building it into a toaster (or any other place a Wii shouldn’t be) is a decent weekend project. Perhaps, a spacier chassis will also help with the overheating problems plaguing some earlier Wii models. One thing we would not recommend, however, is building a toaster into a Wii case – unless you like to see your creations self-immolate, in which case, make sure to film it and grace our Tips line with a YouTube link. There’s also a challenge for the achievement-minded hackers out there – making a rebuild so daring, it gets a DMCA notice from Nintendo.
It wouldn’t be the first time we feature a Nintendo console reborn in a toaster’s shell, with NES and SNES projects coming to mind. If you’re interested in other directions of Wii rebuilds, perhaps you could make an Altoids-sized FrankenWii, or an unholy hybrid of three consoles. And if you do build a Switchster, or a ToaDSter (perhaps, best suited for a waffle iron), we’d love to take a look!
9 thoughts on “Wii Meets Its End In Breadcrumb Jail
  1. Holy toaster!
    This is not funny! :.(
    It’s reserved for NetBSD!
    Please redo this with a coffee brewer, sodastreamer, model truck, …
    :-Þ
    (-: …and don’t take these lines too serious… :-)
      1. With how many mods I know exist to make a Wii fit an even smaller space, and how small it is anyway that should be very possible, and for my money that is what you need – all that waving your arms around means you are going to need a nice bit of toast.
        The real challenge is being able to make toast many times while the Wii still runs – actually keeping the Wii side cool enough to run properly could be a real challenge for the full size Foldi approved toast quantity – once slice is just disappointing, two for a bloke of my size barely counts as a snack, three slices or higher, and doing them one at a time (which is acceptable enough – it takes time to slather them in marmalade/honey/jam/other and eat so the next one is just about ready when the first is consumed) means having a heater running for several mins right next to the Wii..
        Seriously though it looks great.
Leave a Reply to asheetsCancel reply
