Out of all the laptop upgrade options typically available, you wouldn’t expect this specific one. [controlmypad] decided to take a part of his RS485 device programming workflow and put it inside of a spare laptop he picked up for cheap. Typically, he’d occupy some desk space and lay out an unwieldy combination of a USB-RS485 dongle, a PoE power injector, a PSU for that injector, and a few cables to join it all – being extra weight in the tool bag, cluttering the workspace when laid out, and the RS485 adapter slowly wearing out the USB ports during the work-related motions. No reason that all of this couldn’t be packed inside a laptop, however.
What helps a lot is that, in many modern cheap laptops, the motherboard is fairly small, and the DVD drive plastic placeholder can be omitted without second thought. Cutting off the plastic molding from both of the adapters turns them into a nicely reusable circuit board and a small PoE module, respectively. After laborious yet careful cutting of the laptop case with a hobby knife, the PoE injector fits right in and, essentially, adds an extra RJ45 port to the laptop. From where the Hackaday.io write-up left off, it doesn’t seem like this mod got fully completed, but most of the important details are there for us to learn from. What got left out is connecting it to an internal USB port (should help that the motherboard’s schematics are available online), as well as creating 12V-24V from the laptop’s power rails. At this point, however, this mod is a big step forward usability-wise, even if it still requires an external PSU.
Laptop internal upgrade projects are rare but cherished – it’s a combination of “daring”, “inquisitive” and “meticulous” that results in people successfully hacking on a thing they certainly were not meant to hack, and have that thing serve their needs better. Apart from all the EEE PC upgrade options that set the bar for a generation of laptop modders, there’s a myriad of unconventional laptop modification vectors – you could do a thorough from-scratch Type-C charging port conversion, replace your webcam with an FSF-endorsed open firmware WiFi dongle, build in a “12-axis” sensor for auto-orientation and data-logging, or invent a remote self-destruct mechanism for your laptop. Those are, indeed, quite a few things you won’t typically find in the list of available options while customizing your laptop at the manufacturer website.
Hah, for five years from now I wanted to repurpose the RJ10 phone modem connector on my Dell notebook with a mini PCIe CAN/RS485 card and some extra cable. Unfortunately I messed up the offset on the pins so my prototypes did not worked.
Gives me an idea to make a POE powered laptop, giving you 3 choices for power. I currently have a 15′ power cord to the brick, and have had to stretch THAT to use my laptop where I want to in a server room. Of course there’s power on the rack, but many times they’re fully populated and the UPS is at the bottom under a pile of wires. And nothing but twist locks free on the wall. Any place with a bunch of AP’s or cameras will have a POE switch.
Twist-lock to NEMA 5 adapter?
Hmm, 25W or so (max you can get at 48V AFAIU) isn’t all that much for typical laptops – perhaps, if you find a way to limit the charge rate somehow? Certainly would be good for a netbook, though!
I sort of wonder if such a mod done without care will degrade the laptops EMC performance. Leaking lots of noise out, and being suceptable to any stray RF… Plus, the electrical safety aspect too.
Take care peeps.
Not all that different from, well, connecting USB peripherals to your laptop. Otherwise, it’s not shielded any worse than the original laptop was, arguably, even better in some aspects!
