Guitars are most typically built out of wood. Whether it’s an acoustic guitar with a big open cavity, or a solid-body electric, there’s generally a whole lot of wood used in the construction. However, [Mattias Krantz] shows us that alternative construction methods are entirely possible, by building his own balloon guitar.
The balloon guitar still has a neck, bridge, and strings just like any other. However, in place of the resonant cavity of an acoustic guitar, there is provision to install a large balloon instead. It’s actually quite interesting to watch — with the balloon installed, the guitar delivers much more volume than when played without a resonant cavity at all.
The guitar was actually built to test if swapping out air in the balloon for helium would shift the pitch of the sound. Of course, a guitar’s pitch comes from the tension on the vibrating strings, so changing the gas in the resonant cavity doesn’t directly affect it. Instead, much like inhaling helium to affect the human voice, the change is to the timbre of the sound, not the fundamental pitch itself. It sounds as if the guitar has been given a subtle treble boost.
It’s a fun build, and one that shows us that it’s possible to build musical instruments in many ways, not just using traditional techniques. If you want to further play with your guitar’s sound, though, consider turning to the world of machine learning.
Ppl: “You can’t make music out of a bag of breath”
Scotsman: “You wannae bet laddie?”
… after a few minutes of impromptu bagpipe noises reminiscent of a strangled cat…
Ppl: I rest my case!
Being an engineer is apparently not the same as having fabrication skills
It means they can design something, not that they can execute said design
This is the first thing you learn if you ever work with engineers.
Whether the helium changes the sound of the instrument, it’s time to learn to play “Classical Gas”.
this is awsome and absurd,ANYTHING for a sound,but allas
tone is in the hands
I now want an M&M guitar.
Where did I put that Woopy Cushion?
To make an instrument play at a higher pitch with Helium you would need to inhale the Helium and then blow into either a brass or reed instrument.
