Brushless motors are fascinating devices that come in all sorts of shapes and sizes, but you’ve probably never seen one in the form of a free-spinning shiny metal egg. Created by [David WindestÃ¥l], [Giacomo Di Muro], and [Chad Kapper], the Motion Zero is part top, part brushless motor, and fully mesmerizing. Tech overview video after the break.
Like the classic Tippe Top toy, an ovoid shape like this shiny metal egg will stand on its end if it’s spun fast enough. To do this, the team embedded magnets in the metal egg, effectively turning it into a rotor. An array of 4 PCB coils under a smooth concave surface serves as the stator. Because the egg is not held in position by a shaft, hall effect sensors were incorporated to determine the position of the egg, and properly control the state of the coils to keep it spinning.
Recognizing how easy it was to get lost in thought while staring at a shiny spinning egg, the rest of the device was designed with meditation in mind. The top cover is a block of aluminum machined with ripple patterns, with ball bearings that slide between the ripples as the control interface. Additional hall effect sensors on the PCB determine the position of the balls to adjust the rotation speed and shut-off timer. You can even choose to make the egg move around or remain in one position. The main controller is an ESP32 module, which reads all the hall effect sensors and controls the coils via motor drivers.
The Motion Zero has made its debut on Kickstarter and already exceeded its initial funding goal. We like the creators’ willingness to share the inner workings of a product that manages to transform a simple concept into a mesmerizing piece of engineering artistry.
We’ve seen a good bit of [David WindestÃ¥l]’s has a fascination with weird tech over the years, like racing belt sanders, fire breathing waterfowl, tri and bicopters. He even built a prop anti-drone RF cannon for a movie.
Huh. At present, the title does not display on the Hackaday blog page. Works fine on the article page.
Weird!
^. Title Noticer, may your name live on past this current noticing.
Yeah, that’s very strange indeed. And it’s only this one post. We’ll have to have a look.
Yay! We found an obscure checkbox that nobody had ever checked before. Apparently its only function is to mess up our web theme.
Going over the page HTML with a fine-toothed comb did the trick.
Is this not Nikola Tesla’s Egg Of Columbus?
First thing that came to my mind also.
No, because this has magnets in it. The Egg of Columbus uses eddy current drag.
Actually yes, when they tried Teslas Egg the way is written in the patent – it didnt work.
To make it work you need magnet or some did it with wire inside.
Tesla said he patented 800 patents but he had 3 times more in his head. I guess he left lot of in his head and for us to play around.
“It’s like when you push a kid on a swing, and then punch him in the face”
I never thought of magnets like that..
https://youtu.be/8f64QdS8eic?feature=shared&t=167
Looks like a copy of carl bugeja pcb motor, for me.
The video gives him credit for the idea.
Longtime marriaged people will put the plate on the seat and the egg into…
They must concentrate If they want to feel the turning INSIDE…
Ommmmmmm…Meditation Level six, 500 RPM.
I wish they offered more colors (colours-Jenny) for the “egg” and platter.
Yeah, there’s totally no headline for the article on the blog page. (Had to double-check that it wasn’t intentional).
Love the concept, and the execution is beautiful (and super thin!)
Or use eddy current dragging with no magnets in the object that is spinning.
https://youtu.be/c2xL8j-KvF8?si=G41665CUF6jV2C14
