Drones are a pain, especially mini ones. When you are designing, building (or even reviewing) them, they inevitably fly off in some random direction, inevitably towards your long-suffering dog, hit him in the butt and send him scuttling off in search of a quieter spot for a nap.
[Tristan Dijkstra] and [Suryansh Sharma] have a solution: a mini-drone test gimbal. The two are in the the Networked Systems group and the Biomorphic Intelligence LabĀ who use CrazyFlie drones in their work, which require regular calibration and testing. This excellent design allows the drone to rotate in three dimensions, while still remaining safely contained. That means I could test the flight characteristics of a drone without endangering my dogs important napping schedule.
Efforts involved attaching a light tether that restricts the drone until we know how the it flies, but what usually happens is that the tether gets trapped in a rotor, or the tether gets tight and the drone freaks out and crashes into the ground.
Using a gimbal is far more elegant, because it allows the drone to rotate freely in three dimensions, so the basic features of the drone can be established before you let it loose in the skies.
The gimbal was designed with the CrazyFlie in mind, but as there’s nothing more exotic holding the craft down than a zip tie, it should work with similarly sized quadcopters.
It’s the Matrix, but for drones instead of humans!
More like the movie ‘Contact’ 1997.
It’s a good idea, if I ever dip my toes into drone building, I’d be sure to build something like this! Maybe even active gimbal with steppers so that the drone may ‘feel’ motion and challenge the motion algorithm.
Oh my ⦠Iām laughing hard at the first paragraph. Almost makes me think our favorite hyperbolist, Brian Benchoff, has risen from the Hackaday writers grave and reappeared! š¤£
Builder of drones here – not sure this is the best way to go about tuning. For a quad you can put one axis in a ‘yoke’ to tune the PIDs of the opposite access, then rinse/repeat. For multirotor or yaw tuning, there are drone test stands you can buy (or build) for cheap that hold the drone from the bottom and give a good amount of freedom.
Tethering a drone during development is without a doubt a terrible, terrible idea. Agree completely with that point. If/when the tether gets tight the control loops freak out. Similarly, using a gimbal allows for gimbal-lock scenarios which will also confuse the aircraft as inputs in one plane will result in movement in another.
The biggest (only?) upside of this test rig would be testing inverted flight, which most test stands don’t support. Suffice to say this is a very unusual application for most multirotor aircraft.
