An Open SPARCstation USB Keyboard&Mouse Adapter
A USB3SUN adapter, connected to a SPARCstation on one end and to a keyboard on another, with the OLED screen showing status icons
Got a SPARCstation? You might have had to deal with the proprietary DIN port used for keyboard and mouse input. However, you need not look for outdated hardware anymore – we’ve recently found an adapter project called [usb3sun], which lets you use a regular USB keyboard and mouse instead! Designed by [delan] from [the funny computer museum], the usb3sun adapter is featureful, open-source, and even comes with four blog posts describing its inner workings and development process!
Based on a Pi Pico board, this adapter has a ton of quality of life features – an OLED screen for status display, extra USB port and headers for debugging, a buzzer to emulate bell and click functions, power LEDs, and all the ports you would expect. The OLED screen is needed just because of how many features this adapter’s firmware has, and you’re bound to get more – the [usb3sun] firmware is being actively updated to this day. It’s as if this adapter aims to do all it possibly could help you with – for instance, one of the firmware updates has added idprom reprogramming features, which, as [delan] tells us, lets you boot your workstation with a dead NVRAM battery.
You can order the adapter PCBs yourself, you can breadboard it by following detailed instructions from [delan], or you can get a fully assembled and tested [usb3sun] adapter on Tindie! This adapter will seriously help you in your SPARCstation forays, and, if you don’t happen to own a SPARCstation, you can always emulate SunOS.
12 thoughts on “An Open SPARCstation USB Keyboard&Mouse Adapter
    1. They are not. ADB uses a singel wire for communication and SPARC stations use 3 for communication, 2 for the keyboard and 1 for mouse.
  1. I go the other way – I use SUN keyboards with my PCs, but that’s easy because the newer keyboards are USB. Just gotta find the right sort: make sure it *is* USB, make sure Backspace is above the return key without an intervening key, make sure backspace is in the right place (for me – UK position) and make sure the keys haven’t yellowed too much.
    Why? You get a set of 10 dedicated keys for Cut/Copy/Paste, Undo, Redo, etc which I like. Just needs a bit of initial fiddling in KDE settings and it all works.
  2. This solution would have been fantastic in 1994-1996, for a SPARC 2 and SPARC 10. Tried different solution none of them worked at the time.
Leave a Reply to MrSVCDCancel reply
