The MAX30105 is an optical sensor capable of a great many things. It can sense particulate matter in the air, or pick up the blinking of an eye. Or, you can use it as a rudimentary way to measure your heart rate and blood oxygen levels. It’s by no means a medical grade tool, but this build from [Taste The Code] is still quite impressive.
The MAX30105 contains red, green, and infrared LEDs, and a very sensitive light detector. The way it works is by turning on its different LEDs, and then carefully measuring what gets reflected back. In this way it can measure particles in the air, such as smoke, which is actually what it was designed for originally. Or, if you press your finger up against it, it can measure the light coming back from your blood and determine its oxygenation level. By detecting the variation in the light over time, it’s possible to pick up your pulse, too.
Getting this data out of the sensor is remarkably easy. One need only hook it up to a suitable microcontroller like the ESP8266 and use the MAX3010X library to talk to it. [Taste The Code] did exactly that, and also hooked up a screen for displaying the captured data. Alternatively, if you want the raw data from the sensor, you can get that too.
It should be noted that this build was done for educational purposes only. You shouldn’t rely on a simple DIY device for gathering useful medical data; there are reasons the real gear is so expensive, after all. We’ve looked at this sensor before, too, not long after it first hit the market.
Neat, I questioned whether an air quality sensor would sample fast enough for heart rate monitoring, but it turns out the chip goes up to 3200 sampler per second
Sparkfun had all example code on their website for a while now:
https://learn.sparkfun.com/tutorials/max30105-particle-and-pulse-ox-sensor-hookup-guide/all
These “sponsored by” some pcb manufacturer have created lots of new video’s of old information.
Did you intend to insert the same video twice, or was there supposed to be a second video?
Aside “because we can” (which is totally fine!) is there some benefit here I don’t see?
The Max30101 is essentially the same price and as far I can tell the Max30105 is EOL?
Don’t expect much.
“You shouldn’t rely on a simple DIY device for gathering useful medical data”
My doctor refuses to look at my arduino-based EKG strips.
Or… you’ve been living among smoke stacks way too long and it IS picking up the particulates it was designed for.. in your blood!
