Uncovering Secrets Of Logitech M185’s Dongle
the Logitech receiver in question next to the mouse it's paired to
[endes0] has been hacking with USB HID recently, and a Logitech M185 mouse’s USB receiver has fallen into their hands. Unlike many Logitech mice, this one doesn’t include a Unifying receiver, though it’s capable of pairing to one. Instead, it comes with a pre-paired CU0019 receiver that, it turns out, is based on a fairly obscure TC32 chipset by Telink, the kind we’ve seen in cheap smart wristbands. If you’re dealing with a similarly obscure MCU, how do you even proceed?
In this case, GitHub had a good few tools developed by other hackers earlier — a Ghidra integration, and a tool for working with the MCU using a USB-UART and a single resistor. Unfortunately, dumping memory through the MCU’s interface was unreliable and frustrating. So it was time to celebrate when fuzzing the HID endpoints uncovered a memory dump exploit, with the memory dumper code helpfully shared in the blog post.
From a memory dump, the exploration truly began — [endes0] uncovers a fair bit of dongle’s inner workings, including a guess on which project it was based on, and even a command putting the dongle into a debug mode where a TC32-compatible debugger puts this dongle fully under your control.
Yet another hands-on course on Ghidra, and a wonderful primer on mouse dongle hacking – after all, if you treat your mouse’s dongle as a development platform, you can easily do things like controlling a small quadcopter, or pair the dongle with a SNES gamepad, or build a nifty wearable.
We thank [adistuder] for sharing this with us!
18 thoughts on “Uncovering Secrets Of Logitech M185’s Dongle
  1. Some months ago in an attempt to not have to spend $20 on another unifying receiver, I tried to see if I can use an old, thumbdrive sized dongle that came with a Logitech KBM set.
    To my surprise it uses almost the same chip as the (early) unifying receivers (nrf24). However it’s the OTP variant, which means it has a limited number of permanent pairings and cannot have its firmware updated.
    I got it to pair with my mouse, unfortunately it uses a different USB ID so the logitech software wouldn’t work with it and there was no way to change that.
    While looking up all this stuff I also found Logitech have used 2 different chips for their receivers, nrf24 (OTP & flash) and a TI chip. Both compatible with each other afaik. I wonder if this one is as well despite not being branded unifying.
    1. I don’t believe that’s correct. The M235 has side grip panels that are concave and the top panel comes to more of a point at the rear of the mouse, whereas the shiny grey plastic surround on the M185 has a more “constant width” look from the top, as shown in the pic here.
      Source: have junked far to many M185s with their non-pairable receivers for my liking (also Google image search, lol). I’m excited to see the progress made in this project!
        1. I have two Logitech K 235 wireless keyboards that apparently have a unique dongle. The original dongles disappeared. Any thought on how to pair them with another dongle as they won’t pair with the unifying receiver?
        2. Never happened for me.
          Unless it’s a deliberate “tweak” in the Logitech software, the “newer”, non-Unifying M185s were not seen by the Unifying receivers ever, and I tried several times over the years, until I realized there are 2 versions of this mouse.
Leave a Reply to xchrisCancel reply
