Small Print Bed? No Problem!
One of the major limitations of 3D printers is the size of the printable area. The robotic arm holding the printer head can only print where it can reach, after all. Some methods of reducing this constraint have been tried before, largely focusing on either larger printers or printer heads that are mobile in some way. Another approach to increasing the size of prints beyond the confined space typical of most consumer-grade 3D printers is to create some sort of joinery into the prints themselves so that larger things can be created. [Cal Bryant] is developing this jigsaw-based method which has allowed him to produce some truly massive prints.
Rather than making the joints by hand, [Cal]’s software will cut up a model into a certain number of parts when given the volume constraints of a specific 3D printer so it can not only easily print the parts, but also automatically add the jigsaw-like dovetail joints to each of the sections of the print. There were a few things that needed prototyping to get exactly right like the tolerance between each of the “teeth” of the joint, which [Cal] settled on 0.2 mm which allows for a strong glued joint, and there are were some software artifacts to take care of as well like overhanging sections of teeth around the edges of prints. But with those edge cases taken care of he has some working automation software that can print arbitrarily large objects.
[Cal] has used this to build a few speaker enclosures, replacing older MDF designs with 3D printed ones. He’s also built a full-size arcade cabinet which he points out was an excellent way to use up leftover filament. Another clever way we’ve seen of producing prints larger than the 3D printer is to remove the print bed entirely. This robotic 3D printer can move itself to a location and then print directly on its environment.
7 thoughts on “Small Print Bed? No Problem!
  1. This is very similar to something I’ve done quite a bit in my day job, which I can’t talk about in detail. But I will note that “jigsaw” is short for “jigsaw puzzle” – you can easily outsmart your future self (and others) with excessively clever schemes.
    I found that the simplest possible scheme works best – just chop the object into printer-sized cubes, with registration holes sized to use bits of filament as dowels. And most importantly, have a consistent system for numbering the pieces.
  2. Stick a print head and a leap motion on the end of a robotic arm, scan the surface and print wherever calibrating as you go. Perhaps even using other physical objects instead of the bulk of the support material.
  3. For most kind of to huge for my printbed flat parts I use a single or two simple “straight down” dovetails with 60° angles. The cut I use is just 0.1mm wide. I chamfer the sharp edges of the dovetail itself so both parts slide together easily. For one dovetail it’s just drawing 5 lines across the parting line…
    I use a few drops of quite viscous super glue to fix the parts and then let water thin super glue seep into the cracks. Activator helps with super glue of course.
  4. PrusaSlicer and its forks have had the ability to cut up models and then provide various registration pins for ages, now. I use it now and then and it’s super useful. Cool to see more techniques in the wild though!
Leave a Reply to CRJEEACancel reply
