Expensive Camera, Cheap 3D-Printed Lens
If you’re a photography enthusiast, you probably own quite a few cameras, but the chances are your “good” one will have interchangeable lenses. Once you’ve exhausted the possibilities of the kit lens, you can try different focal lengths and effects, but you’ll soon find out that good glass isn’t cheap. Can you solve this problem by making your own lenses? [Billt] has done just that.
Given some CAD skills, it’s possible to replicate the mount on an existing lens, but he takes a shortcut by using a readily available camera cap project. There are two lenses detailed in the video below the break; the first is a plastic lens from a disposable camera, while the second takes one from a Holga toy camera. The plastic lens is inserted mid-print, giving the colour aberrations and soft focus you’d expect, while the Holga lens is mounted on a slide for focusing. There may be some room for improvement there, but the result is a pair of fun lenses for experimentation for not much outlay. Given the number of broken older cameras out there, it should be relatively easy for anyone wanting to try this for themselves to have a go.
The video is below the break, but while you’re on this path, take a look at a previous project using disposable camera lenses. Or, consider printing an entire camera.
8 thoughts on “Expensive Camera, Cheap 3D-Printed Lens
  1. I only read the article but there are already cheap holga lenses available on Amazon for a ton of different mounts. They are great $15 toys to throw on a camera.
  2. I would be concerned about small shards of plastic from the print landing on the image sensor and getting inside the camera body to cause on-going problems as they move around.
Leave a Reply to Ray MorrisCancel reply
