Reconductoring: Building Tomorrow’s Grid Today
What happens when you build the largest machine in the world, but it’s still not big enough? That’s the situation the North American transmission system, the grid that connects power plants to substations and the distribution system, and which by some measures is the largest machine ever constructed, finds itself in right now. After more than a century of build-out, the towers and wires that stitch together a continent-sized grid aren’t up to the task they were designed for, and that’s a huge problem for a society with a seemingly insatiable need for more electricity.
There are plenty of reasons for this burgeoning demand, including the rapid growth of data centers to support AI and other cloud services and the move to wind and solar energy as the push to decarbonize the grid proceeds. The former introduces massive new loads to the grid with millions of hungry little GPUs, while the latter increases the supply side, as wind and solar plants are often located out of reach of existing transmission lines. Add in the anticipated expansion of the manufacturing base as industry seeks to re-home factories, and the scale of the potential problem only grows.
The bottom line to all this is that the grid needs to grow to support all this growth, and while there is often no other solution than building new transmission lines, that’s not always feasible. Even when it is, the process can take decades. What’s needed is a quick win, a way to increase the capacity of the existing infrastructure without having to build new lines from the ground up. That’s exactly what reconductoring promises, and the way it gets there presents some interesting engineering challenges and opportunities.
Bare Metal
Copper is probably the first material that comes to mind when thinking about electrical conductors. Copper is the best conductor of electricity after silver, it’s commonly available and relatively easy to extract, and it has all the physical characteristics, such as ductility and tensile strength, that make it easy to form into wire. Copper has become the go-to material for wiring residential and commercial structures, and even in industrial installations, copper wiring is a mainstay.
However, despite its advantages behind the meter, copper is rarely, if ever, used for overhead wiring in transmission and distribution systems. Instead, aluminum is favored for these systems, mainly due to its lower cost compared to the equivalent copper conductor. There’s also the factor of weight; copper is much denser than aluminum, so a transmission system built on copper wires would have to use much sturdier towers and poles to loft the wires. Copper is also much more subject to corrosion than aluminum, an important consideration for wires that will be exposed to the elements for decades.
ACSR (left) has a seven-strand steel core surrounded by 26 aluminum conductors in two layers. ACCC has three layers of trapezoidal wire wrapped around a composite carbon fiber core. Note the vastly denser packing ratio in the ACCC. Source: Dave Bryant, CC BY-SA 3.0.
Aluminum has its downsides, of course. Pure aluminum is only about 61% as conductive as copper, meaning that conductors need to have a larger circular area to carry the same amount of current as a copper cable. Aluminum also has only about half the tensile strength of copper, which would seem to be a problem for wires strung between poles or towers under a lot of tension. However, the greater diameter of aluminum conductors tends to make up for that lack of strength, as does the fact that most aluminum conductors in the transmission system are of composite construction.
The vast majority of the wires in the North American transmission system are composites of aluminum and steel known as ACSR, or aluminum conductor steel-reinforced. ACSR is made by wrapping high-purity aluminum wires around a core of galvanized steel wires. The core can be a single steel wire, but more commonly it’s made from seven strands, six wrapped around a single central wire; especially large ACSR might have a 19-wire core. The core wires are classified by their tensile strength and the thickness of their zinc coating, which determines how corrosion-resistant the core will be.
In standard ACSR, both the steel core and the aluminum outer strands are round in cross-section. Each layer of the cable is twisted in the opposite direction from the previous layer. Alternating the twist of each layer ensures that the finished cable doesn’t have a tendency to coil and kink during installation. In North America, all ACSR is constructed so that the outside layer has a right-hand lay.
ACSR is manufactured by machines called spinning or stranding machines, which have large cylindrical bodies that can carry up to 36 spools of aluminum wire. The wires are fed from the spools into circular spinning plates that collate the wires and spin them around the steel core fed through the center of the machine. The output of one spinning frame can be spooled up as finished ACSR or, if more layers are needed, can pass directly into another spinning frame for another layer of aluminum, in the opposite direction, of course.
Fiber to the Core
While ACSR is the backbone of the grid, it’s not the only show in town. There’s an entire beastiary of initialisms based on the materials and methods used to build composite cables. ACSS, or aluminum conductor steel-supported, is similar to ACSR but uses more steel in the core and is completely supported by the steel, as opposed to ACSR where the load is split between the steel and the aluminum. AAAC, or all-aluminum alloy conductor, has no steel in it at all, instead relying on high-strength aluminum alloys for the necessary tensile strength. AAAC has the advantage of being very lightweight as well as being much more resistant to core corrosion than ACSR.
Another approach to reducing core corrosion for aluminum-clad conductors is to switch to composite cores. These are known by various trade names, such as ACCC (aluminum conductor composite core) or ACCR (aluminum conductor composite reinforced). In general, these cables are known as HTLS, which stands for high-temperature, low-sag. They deliver on these twin promises by replacing the traditional steel core with a composite material such as carbon fiber, or in the case of ACCR, a fiber-reinforced metal matrix.
The point of composite cores is to provide the conductor with the necessary tensile strength and lower thermal expansion coefficient, so that heating due to loading and environmental conditions causes the cable to sag less. Controlling sag is critical to cable capacity; the less likely a cable is to sag when heated, the more load it can carry. Additionally, composite cores can have a smaller cross-sectional area than a steel core with the same tensile strength, leaving room for more aluminum in the outer layers while maintaining the same overall conductor diameter. And of course, more aluminum means these advanced conductors can carry more current.
Another way to increase the capacity in advanced conductors is by switching to trapezoidal wires. Traditional ACSR with round wires in the core and conductor layers has a significant amount of dielectric space trapped within the conductor, which contributes nothing to the cable’s current-carrying capacity. Filling those internal voids with aluminum is accomplished by wrapping round composite cores with aluminum wires that have a trapezoidal cross-section to pack tightly against each other. This greatly reduces the dielectric space trapped within a conductor, increasing its ampacity within the same overall diameter.
Unfortunately, trapezoidal aluminum conductors are much harder to manufacture than traditional round wires. While creating the trapezoids isn’t that much harder than drawing round aluminum wire — it really just requires switching to a different die — dealing with non-round wire is more of a challenge. Care must be taken not to twist the wire while it’s being rolled onto its spools, as well as when wrapping the wire onto the core. Also, the different layers of aluminum in the cable require different trapezoidal shapes, lest dielectric voids be introduced. The twist of the different layers of aluminum has to be controlled, too, just as with round wires. Trapezoidal wires can also complicate things for linemen in the field in terms of splicing and terminating cables, although most utilities and cable construction companies have invested in specialized tooling for advanced conductors.
Same Towers, Better Wires
The grid is what it is today in large part because of decisions made a hundred or more years ago, many of which had little to do with engineering. Power plants were located where it made sense to build them relative to the cities and towns they would serve and the availability of the fuel that would power them, while the transmission lines that move bulk power were built where it was possible to obtain rights-of-way. These decisions shaped the physical footprint of the grid, and except in cases where enough forethought was employed to secure rights-of-way generous enough to allow for expansion of the physical plant, that footprint is pretty much what engineers have to work with today.
Increasing the amount of power that can be moved within that limited footprint is what reconductoring is all about. Generally, reconductoring is pretty much what it sounds like: replacing the conductors on existing support structures with advanced conductors. There are certainly cases where reconductoring alone won’t do, such as when new solar or wind plants are built without existing transmission lines to connect them to the system. In those cases, little can be done except to build a new transmission line. And even where reconductoring can be done, it’s not cheap; it can cost 20% more per mile than building new towers on new rights-of-way. But reconductoring is much, much faster than building new lines. A typical reconductoring project can be completed in 18 to 36 months, as compared to the 5 to 15 years needed to build a new line, thanks to all the regulatory and legal challenges involved in obtaining the property to build the structures on. Reconductoring usually faces fewer of these challenges, since rights-of-way on existing lines were established long ago.
The exact methods of reconductoring depend on the specifics of the transmission line, but in general, reconductoring starts with a thorough engineering evaluation of the support structures. Since most advanced conductors are the same weight per unit length as the ACSR they’ll be replacing, loads on the towers should be about the same. But it’s prudent to make sure, and a field inspection of the towers on the line is needed to make sure they’re up to snuff. A careful analysis of the design capacity of the new line is also performed before the project goes through the permitting process. Reconductoring is generally performed on de-energized lines, which means loads have to be temporarily shifted to other lines, requiring careful coordination between utilities and transmission operators.
Once the preliminaries are in place, work begins. Despite how it may appear, most transmission lines are not one long cable per phase that spans dozens of towers across the countryside. Rather, most lines span just a few towers before dead-ending into insulators that use jumpers to carry current across to the next span of cable. This makes reconductoring largely a tower-by-tower affair, which somewhat simplifies the process, especially in terms of maintaining the tension on the towers while the conductors are swapped. Portable tensioning machines are used for that job, as well as for setting the proper tension in the new cable, which determines the sag for that span.
The tooling and methods used to connect advanced conductors to fixtures like midline splices or dead-end adapters are similar to those used for traditional ACSR construction, with allowances made for the switch to composite cores from steel. Hydraulic crimping tools do most of the work of forming a solid mechanical connection between the fixture and the core, and then to the outer aluminum conductors. A collet is also inserted over the core before it’s crimped, to provide additional mechanical strength against pullout.
Is all this extra work to manufacture and deploy advanced conductors worth it? In most cases, the answer is a resounding “Yes.” Advanced conductors can often carry twice the current as traditional ACSR or ACCC conductors of the same diameter. To take things even further, advanced AECC, or aluminum-encapsulated carbon core conductors, which use pretensioned carbon fiber cores covered by trapezoidal annealed aluminum conductors, can often triple the ampacity of equivalent-diameter ACSR.
Doubling or trebling the capacity of a line without the need to obtain new rights-of-way or build new structures is a huge win, even when the additional expense is factored in. And given that an estimated 98% of the existing transmission lines in North America are candidates for reconductoring, you can expect to see a lot of activity under your local power lines in the years to come.
68 thoughts on “Reconductoring: Building Tomorrow’s Grid Today
    1. There are probably limiting factors such as the insulators on the towers. Upgrading these may help, until you get to the breakdown between wire and tower itself.
      What about DC instead? Would that have less losses over distance – even if you factor in the conversion at both ends to a squllion volts DC?
      1. Humid days and gap between wires are the ultimate limit.
        Once an arc starts the plasma is a good conductor.
        You should never ever release Mylar helium balloons with Mylar ‘strings’ near high tension lines.
        The arcs produced are not ‘free fireworks’.
        Don’t do it!
        Do it wrong and part of the arc is you.
        BTW this is an ad…the ‘advanced conductor’ manufacturers…they’re selling their companies stock though.
        Transmission line upgrades have been under continuous evaluation, for decades.
        Including many cases, cable replacement, tower replacement, to up-volt or covert to DC…
        The cost side is brutal.
        Downtime cost kills many projects in the cradle.
        But if your replacing conductors anyhow…
        Then the EMF twits show up, wearing emergency blankets and clutching crystals.
        1. Then the EMF twits show up, wearing emergency blankets and clutching crystals.
          The EMF twits should then be happy about HVDC transmission lines, unless they’re also afraid of fridge magnets…
      2. Direct Current is better for shorter distances….however it’s inefficient when dealing with power distribution over the grid, to homes. Alternate Current is a big win there.
        1. True for low voltages. Emphatically not true for long-haul high voltage transmission.
          As they say, a little bit of knowledge is a dangerous thing.
    2. Higher voltages require larger insulators, which add weight and cost. At higher voltages, conductors also must be seperated further apart and further from the ground, which means the transmission line towers must be wider, higher, and stronger, adding even more cost. The conductors themselves are a minimal part of the cost of a transmission line.
      Not mentioned in the article is the ‘skin effect,’ which is the tendency of electrons to ‘prefer’ travelling along the outside of a conductor in an AC system. At 50-60 Hz, electrons penetrate the conductor to a depth of less than a centimeter, and even less at higher frequencies. So it’s unusual to see a AC transmission line conductor thicker than 2 cm. To increase current capacity, multiple conductors are used in parallel. I’ve seen 2, 4, and even 6 conductors used per phase in some installations.
      Switching to DC transmission eliminates the problems with skin effect, but adds the cost of conversion back to AC, which can be substantial. The losses converting from AC to DC and back are typically far higher than the losses of an AC transformer. DC lines are most often used to connect different transmission networks together to share power while eliminating problems with phasing, i.e. syncronizing the different networks. A phase shift of only a few degrees between networks can waste considerable power and transmission line planners will sometimes route a line to be somewhat longer to match the AC phases at each end as closely as possible. Inter-electrode capacitance between the long transmission lines can also affect transmission line efficiency and sometimes large high-voltage inductors (often called reactors) are used to bring the phases back in sync.
        1. A Hybrid DC Circuit Breaker (HCB) perhaps. Or the older Mechanical Circuit Breaker (MCB) with Resonant Circuits.
        1. Not really … the cable is a long cylindric capacitor. On AC, you have to charge and discharge it for every cycle, the charge current is added to the load current, and the sum must not exceed the current carrying capability of the cable. Undersea cables tend to be long –> high capacity –> lots of charging current. The only possibility to cut the charging current is lowering the frequency, so you go DC, where you charge the cable once on switch-on and discharge it once on switch-off.
    3. Gets too risky. Lowers the effort required to really mess things up to low. Honestly it’s already a bit too low and we are kind of waiting for someone to be brave enough to prove it..
    4. I’m guessing power companies thing it’s “unethical” and “inefficient” to create a giant bug zapper that takes out nearby pedestrians. A bunch of killjoys is what they are.
  1. Power being produced closer to need. e.g. data centers having renewables nearby. e.g. Texas.
    HTLS using aluminum-zirconium alloys, and cores using fiberglass, or invar steel. In combination with DLR (Dynamic Line Rating) and FACTS (Flexible AC Transmission Systems). As well as HVDC in some circumstances.
    1. Also not mentioned is alternative transmission-line tower designs. e.g. monopole (some using composite materials), compact and artistic designs, multi-circuit/voltage.
      1. Transmission towers are a ‘highly evolved’ structure.
        Nobody is going to make big improvements unless new materials are used.
        Reasonably cheap new materials.
        They’re far to expensive to indulge the artsy-fartsy people.
        Nobody is ever going to actually build the Ti-chi poses transmission line, just render it.
        It’s wrong to say ‘cookbook engineering’, suck a thing doesn’t exist, not even civil.
        But well trodden ground.
    2. for the High Temperature Low Sag conductors and the DLR you also have to watch the temperature of the clips holding the cable: while the cable itself stays cool enough, the clips may trap the heat and become hot spots on the mechanically most critical point of the conductor (and the clips itself have to withstand that higher temperature as well, local wind speed variations may play an important role for cooling effects and must be considered).
    3. Power being produced closer to need. e.g. data centers having renewables nearby
      People have the wrong idea about local renewable energy production. You’d think that a wind turbine or a wind farm nearby is producing energy for you, but it’s the opposite.
      That’s because the average wind power site is only producing significant power some 15% of the time, or about 1 day of the average week. Of course you have weeks when it’s turning constantly, but then you have weeks when the turbines are barely generating anything. In reality 85% of the time the power is coming in from elsewhere.
      Weather fronts are huge, so wind turbine sites correlate in output with one another over huge distances up to 600 miles, which increases the average transmission distance of power and requires building more long-distance transmission capacity. Solar power is even worse because everyone in a 1000 mile radius is getting or not getting power at the same time.
      The only thing in this system that actually gives you power “closer to need” is the gas turbine or the engine generator that gets switched on when the transmission grid is full, or the prices are too high and you can’t buy more power from elsewhere.
  2. … which brings us the point of municipal-level compact modular nuclear reactors that would reduce the need for the long transmission lines … obviously, PROPERLY MAINTAINED and not just outsourced to the cheapest H1B visa holders straight from high school …
    The idea of municipal-level power generation has been around since forever, and have we had THAT happening by now, there would be dozens of independent (NOT locked under the umbrella/parent begemoth corporation) competing with each other, and thus, introducing better solutions for lower price, and less transmission lines, more professional good local jobs kind of deal.
    Presently we have the exact opposite, hence, back to the long transmission lines … longer lines … larger begemoths …. more losses … more government subsidies under the “rural electrification Act” (or whatever it is that Farm Bill is called now) … that’s what this is aiming at, getting more federal-taxes-paid dough … larger power plants … I believe Peter Gabriel has excellent song about that, “Sledgehammer”, “… my house is getting bigger …” and so on : – ]
    1. “not just outsourced to the cheapest H1B visa holders straight from high school”
      While I like the idea of distributed power generation where practical, that is one nasty dog whistle.
      1. So? Not everyone is like you. In fact very few are, and you gotta face that eventually if you claim to be in support of democracy
    2. I am old enough to remember when my county of residence had three power plants.
      One in the North county, one in the south, and one down town in the county seat.
        1. I don’t. I live 2 miles from a now-closed coal plant. Woke up every morning to black sooty dust and small gritty particles all over my car, which stained and pitted the paint. Also, having 3 times as many plants would mean 3x workers, 3x maintenance, 3x the infrastructure to supply fuel, higher total operating costs… how much are you willing to pay for electricity?
          1. It’s a tragedy that the Prime Directive forbids the Federation from sharing Tarp Technology with us.
    3. Id’ keep my (virtual) mouth shut if I didn’t have anything particular in mind.
      Seek ye certain Dense Plasma Focus rabbit hole – a nuclear fusion working concept that can be powered by boron (abundant fuel, btw) and hydrogen and spew forth mostly helium and direct energy (as in “electricity” without the need for the intermediaries, steam turbines, etc). Literally, one blast of the cycle charges supercapacitors. (as a side note, I suspect that THIS particular kind was the basis for the Star Trek New Generation reactor – though, obviously, the “cycles” won’t be noticeable by the average human, but the initial ignition would be).
      Regardless, the top of the wiki article about DPF spells out why it is not favored by the Big Important Governments and Big Important Investors – because it doesn’t nee to be scaled up to the gargantuan proportions to work. Technically speaking, it can be scaled up, of course, but the results would be diminishing returns, which means this could have been a prime candidate for such things, modular municipal reactors.
      There was excellent talk by one of the acolytes, I think he was the engine behind the Focus Society (sadly, the site seem to be abandoned), and I lost the link … but the gist was thus – average investment needed was under 50 mils per few years, hiring mostly engineers, with few working prototypes demonstrating working concepts ready for production, and mentioned Big Bad Investors wanted Big Bad Governments to generate Big Bad Projects with hundreds of bureaucrats looking over few dozens of engineers, which was, basically, the main reason why they cannot get any financing going. They were asking too little (50 mils for someone like Chase or Microsoft or Intel is peanut change – they pay more than that annually to their CEOs and directors).
      If I find the link, I’ll share it – it is excellent primer in many topics at once, nuclear physics included, with peek into quantum mechanics (and not only). Worthy watching and listening to, and about explains just WHY we are not to get anything comparable any time soon, sadly.
      1. Found the link – google “Focus Fusion: The Fastest Route to Cheap, Clean Energy”. Excellent lecture.
        1. I am 53 now, and I did read my first article about (myon catalyzed, low temperature) fusion reactors when I was 12, in Scientific American. As I am German and this foreign magazine was the expensive hobby of my physics teacher, it most probable was an older back issue from the year(s) before, which he gave to the school library.
          Did I see fusion since in the last 41 years?
          no.
          When is it supposed to appear?
          “really soon now™”
          Do I have hope to own a fusion reactor at some point in the statistically 28 years that I have left?
          Unfortunately no.
          1. The Scientific American article about Muon Catalyzed Fusion in the1980’s also stated that the short lifetime of muons and the difficulty of producing them in sufficient quantity meant that this would probably never be a practical energy source.
          2. I totally agree and wish more people had a full perspective on the maturity of fission power, which has been a thing for 74 years, and fusion power, which is not really close to being a thing despite over 100 years of fairly intensive research.
            Fission power timeline:
            1938 – Nuclear fission discovered
            1942 – First large scale controlled fission reaction
            1945 – First large scale uncontrolled fission reaction (trinity test)
            1951 – The first fission produced electricity
            1956 – First commercial fission power plant started up 69 years ago
            Fusion power timeline
            1934 – Nuclear fusion experimentally demonstrated
            1952 – First large scale uncontrolled fusion reaction
            The current endurance record for a controlled fusion reaction is 22 minutes compared to the 28 minutes of controlled fission first achieved 83 years ago.
            Net electricity production by fusion has not been achieved in the 101 years since fusion was first demonstrated in the lab.
            While fusion power research has some value there is no evidence that it is anywhere near the point of producing any electrical output let alone commercial scale electrical output despite over a century of dedicated research. The past few decades of billion dollar efforts have not come anywhere close to pushing fusion technology to the level of commercial viability fission power achieved almost 70 years ago.
            If carbon free base load power is really the goal it seems obvious where more effort should be spent.
          3. I use nuclear fusion every day. The reactor is safely millions of kilometers away in space, and I can collect the energy with these nifty panels of semiconductors on my roof. No moving parts!
    4. The problem with locally generated municipal power can be summed up by NIMBY. People want power, septic services, and garbage collection, but they don’t want it nearby. They want it as far away as possible. Any attempt to do otherwise and the lawsuits start up to stop them and the legal process drags it out for so long that it’s costing too much to fight the opponents. This is why we have the system we do now.
  3. I know I’m going to catch hell for suggesting this, but why haven’t we started burying high tension lines?
    I get it, the cost per linear unit of measure is way higher with underground infrastructure. I also acknowledge that it’s only truly viable in geologically stable regions, which there are plenty of. I’m not talking about a new subway system or eight lane high way here. Small diameter tunnel boring is a bit more common now with Musk’s Boring Company up and running; not saying we use them but we can learn from their mistakes and successes.
    I’d rather pay once for a deep, low maintenance tunnel network than continually paying for high tension lines. Tunnels are protected from the majority of natural disasters and potential CIKR terrorist attacks. They’re comparatively low maintenance if built right.
    1. Cost. If the math comes back saying it’s less cost to put ’em underground, they go underground. And keep in mind that budgets are determined by the lifetime of bureaucracies and administrations, so it isn’t long-term.
    2. The cost an insane fortune and another when they do need maintenance.
      SOP is to install a temporary above ground line when needed for work.
      That doesn’t work at high voltages, so those really should be redundant.
      Which ends the study with a thud.
      Also losses.
      Underground runs hotter but doesn’t droop and dumps heat better.
        1. London Underground is hot because it was built in a biome with active lava flows and many caves. For some reason the same issue doesn’t happen with Paris, Berlin or Moscow metro systems.
          1. Uhhh… what? I’m not aware of any hot flowing lava in London.
            It’s problem is entirely heat soak over long periods of time. Doens to hundreds of feet of dirt make for a great insulator.
          2. London Underground is hot because it was built in a biome with active lava flows
            Was this an episode of Dr Who or something? there’s no lava near the London Underground.
        2. You’re citing a story about a subway system.
          Electric insulators are usually also good thermal insulators, but that’s not universal and plastics can stand higher heat then human subway riders.
          The cables are much much more expensive than hanging ones, similar V and A.
          Devil is always in the details. Details of the soil matter. Water table etc.
          1. Same problem, different flavor. You have to limit the losses to stay within the allowed temperature range, because soil does not conduct heat very well.
          2. Or actively dump heat.
            With a high enough thermal gradient, soil conducts heat ‘well enough’.
            Depending on the soil type and water content.
            Just that whiny brit underground riders can’t stand a ‘high enough thermal gradient’…
          3. theory aside, heat buildup is a known limiting factor for cables, not only in soil, but also in walls, cable ducts, …, and it should at least be considered for cables in deep tunnels as mentioned by KC, as tunnels also suffer from heat buildup, see London Underground
          4. In walls, it’s 99% instantaneous heat that’s an issue.
            Typical slow blow breakers/fuses don’t give you long enough to really build up heat (at the overamp edge).
            Actively dumping heat is not a ‘theory’, but mostly heat pipes/sinks, convection and fans work well enough.
            Of course they work the math.
            But it’s not universally prohibitive.
            Bigger problem is really where the heat comes from, greater losses for non-superconducting underground. 1% of a gigawatt is a lot.
            Granted 1% extra loss isn’t a one furlong/league/km (non-moon walker units used to placate fuzzy foreigners) cable run.
            Anyhow: the obvious solution is diamond as both cable insulator and heat conductor. No voltage is unreachable underground with a enough solid diamond.
    3. Buried gigawatt lines produce a lot of heat. You end up pumping fluid to pull the heat out, and that pump is another failure point and more expense.
      I think these are restricted to big cities where the relatively short runs make the cost bearable.
      It gets pretty exotic. There’s a cryogenic superconducting conductor under the San Francisco Bay, for example.
      1. Ya sure about that?… at least the cryogenic part? I’m guessing you’re referring to the trans bay cable, but it isn’t superconducting
        https://en.m.wikipedia.org/wiki/Trans_Bay_Cable
        I haven’t come accross any mention of a superconducting transmission line of any type mself; mu understanding is that current superconducting materials are too brittle (and costly) to make something like this work.
    4. Underground is practically a high voltage cable buried in a big trench, meaning high stray capacitance (heavily limiting line length and being problematic for grid stability), no fault clearing by switching off the line for a second like on overhead lines, the need to keep the line clear of trees and everything with deep roots, and maintainance is easier when you can just look up to see where the problem is. Common problem with cables is water creeping into the insulation layer, resulting in arcs which have to be localized and dug up for repair, with the repair itself bringing in a higher risk of failing (again) by line inhomogenity.
      And voles love the warmth in the ground next to the line, which is the main reason the farmers here[tm] now much prefer overhead lines again…
    5. Burying anything in a place with winter freeze/thaws is a problem. The ground moves. There is a Fair Ground near me that is built in a flood plain – Buried communication cables placed in a straight dug trench from building to building will fail after a few years. When excavated, the cables will be no longer be straight, instead following the flow of the earth in sweeping ‘S’ curves.
      That and the fact that nothing is going deeper than a few feet without serious blasting and rock cracking in New England.
    6. It is hard to dissapate heat underground so underground lines have very low capacity compared to overhead lines. Plus, as you noted, the cost to install and maintain underground structures is high, thousands of times higher than overhead lines. Elon Musk’s Boring Company is no longer “up and running” having only completed a single project, the 1.7 mile loop of tunnel in Las Vegas back in 2021. You need large diameter tunnels for high voltage high power cables to give space for maintenance and cooling. As Elon discovered, those tunnels are very expensive to build.
      Underground is best for “last mile” distribution in neighborhoods where voltages are lower and power levels are low enough that heat dissapation is less problematic. There you can just dump plastic insulated cables in a 6 foot deep trench and call it done. It is a bit more complicated with 250 KV transmission lines.
  4. The core can be a single steel wire, but more commonly it’s made from seven strands, six wrapped around a single central wire;
    i wonder if they’ve considered seven around two, wrapped by one
  5. I feel sorry for the swamp Germans though.
    They think it’s the government’s job to run the grid.
    Truth.
    I’ve consulted for the main Dutch power company.
    Note: nonprofit NGO, not government.
    Swamp German leaders know better.
    Also:
    Client facing engineer to applied math PhD. ‘Fix the model or I’m sending you to Amsterdam to explain personally.’
    Me: ‘What can I break to get sent to Amsterdam? Say the word and it’s as good as broken.’
    It was some time ago, when Amsterdam was ‘known’ to make Vegas look like Topeka.
  6. I see my comments being removed. I am not a troll, but complex/advanced topics cannot be discussed in few paragraphs.
    Regardless, municipal nuclear reactors would ease up the need for the long transmission lines.
  7. Are we even capable of re-tooling our infrastructure at this point? Here in the southeast we still haven’t repaired the damage from Helene. If you start looking elsewhere in the world, the trend is to move away from a centralized grid and toward local solar/battery installations, as well as learning to live with intermittent electricity. We have to accept the limitations of modern humans. For whatever reason, we can’t do the stuff we used to.
  8. Good article. I am going to cast doubt on the “largest machine in the world” claim. If I accept the premise that a power grid is a machine, I’d still say the Eastern Interconnect, Western Interconnect, and Texas Interconnect are separate grids and accordingly separate machines. Each of those grids are phase synchronized at nominally 60Hz (which is amazing to think about), which could be considered a single machine, or a single system. But there isn’t synchronization between grids. Each is separate, with a few HVDC links.
    The European grid is bigger than any individual American grid. Apparently the Northern China grid has more power on it than any of these (Wikipedia), but the Europe grid does cover a larger area and probably has more transmission routes to more locations. Your call about which is a bigger machine.
    1. There was a cool story recently where the Baltic countries changed their grid to synchronise with the European grid instead of the Russian one. They did a whole bunch of planning, then went through the procedure, and it Just Worked. I don’t know if most of Europe even know it happened. The best thing is it was all so smooth we don’t have to sit here and read a bunch of armchair experts telling us what they did wrong :-)
Leave a Reply to Suppressed CarrierCancel reply
