Static Electricity Remembers
As humans we often think we have a pretty good handle on the basics of the way the world works, from an intuition about gravity good enough to let us walk around, play baseball, and land spacecraft on the moon, or an understanding of electricity good enough to build everything from indoor lighting to supercomputers. But zeroing in on any one phenomenon often shows a world full of mystery and surprise in an area we might think we would have fully understood by now. One such area is static electricity, and the way that it forms within certain materials shows that it can impart a kind of memory to them.
The video demonstrates a number of common ways of generating static electricity that most of us have experimented with in the past, whether on purpose or accidentally, from rubbing a balloon on one’s head and sticking it to the wall or accidentally shocking ourselves on a polyester blanket. It turns out that certain materials like these tend to charge themselves positively or negatively depending on what material they were rubbed against, but some researchers wondered what would happen if an object were rubbed against itself. It turns out that in this situation, small imperfections in the materials cause them to eventually self-order into a kind of hierarchy, and repeated charging of these otherwise identical objects only deepen this hierarchy over time essentially imparting a static electricity memory to them.
The effect of materials to gain or lose electrons in this way is known as the triboelectric effect, and there is an ordering of materials known as the triboelectric series that describes which materials are more likely to gain or lose electrons when brought into contact with other materials. The ability of some materials, like quartz in this experiment, to develop this memory is certainly an interesting consequence of an otherwise well-understood phenomenon, much like generating power for free from static electricity that’s always present within the atmosphere might surprise some as well.
12 thoughts on “Static Electricity Remembers
  1. So they developped a memory cell. I wonder whether it could be made into a logical element with the goald of a static electricity computer in mind
    1. I know it’s different than what they showed in the video, but FLASH, (E)EPROMS, RAM are static electricity memories and FET transistors are electrostatic induction elements – charged by electric current, not by touching the parts like in the video.
  2. How is this “memory” not just “some materials can be charged with a (variable) static charge”? This reads as if somebody discovered that capacitors have a memory!!
    1. This article is hard to interpret, but having read the research a while back, it’s more like: the more times you reuse a material in your triboelectric experiments, the more contaminated it gets and the less reliable the ordering you produce.
      1. I’m not sure if that’s all that they were found (it’s actually was known for at least 30 years – I’ve read about this as a teen), but in result the text of article is this.
    2. And magnets have memory. Oh, and some dielectrics have memory of being subjected with too high voltage -their resistance degrades.
      We also can use light to charge or discharge material.
Leave a Reply to NathCancel reply
