Why Apple Dumped 2,700 Computers In A Landfill In 1989
In 1983, the Lisa was supposed to be a barnburner. Apple’s brand-new computer had a cutting edge GUI, a mouse, and power far beyond the 8-bit machines that came before. It looked like nothing else on the market, and had a price tag to match—retailing at $9,995, or the equivalent of over $30,000 today.
It held so much promise. And yet, come 1989, Apple was burying almost 3,000 examples in a landfill. What went wrong?
Continue reading “Why Apple Dumped 2,700 Computers In A Landfill In 1989”
3D printed rotary table
Bearing Witness: Measuring The Wobbles In Rotary Build
3D printing has simplified the creation of many things, but part of making something is knowing just how much you can rely on it. On the [BubsBuilds] YouTube channel, he built a cheap rotary table and then walked through the process of measuring the error inherent in any rotating system.
Starting with a commercial rotary table, [BubsBuilds] decided he wanted a rotary stage that was both lighter and had provisions for motorized movement. Most of the rotary build is 3D printed, with the large housing and table made from PETG, and the geared hub and worm gear printed on a resin printer. The bearings used to support the worm gear are common skateboard bearings. There is also a commercial thrust bearing and 49 larger 9.5 mm ball bearings supporting the rotating tabletop.
There are three different types of runout to be measured on a rotating stage: axial, radial, and angular. Axial runout is fairly straightforward to discern by measuring the vertical variation of the table as it rotates. Radial runout measures how true the rotation is around the center of the table. Angular runout measures how level the table stays throughout its range. Since these two runouts are tied to each other, [BubsBuilds] showed how you can take measurements at two different heights and use trigonometry to obtain both your radial and angular runout
This is a great walk-through of how to approach measuring and characterizing a system that has multiple variables at play. Be sure to check out some of the other cool rotary tables we’ve featured.
Continue reading “Bearing Witness: Measuring The Wobbles In Rotary Build”
Reverse Engineering A ‘Tony’ 6502-based Mini Arcade Machine
The mainboard of the mini arcade unit with its blob chip and EEPROM. (Credit: Poking Technology, YouTube)
For some reason, people are really into tiny arcade machines that basically require you to ruin your hands and eyes in order to play on them. That said, unlike the fifty gazillion ‘retro consoles’ that you can buy everywhere, the particular mini arcade machine that [David Given] of [Poking Technology] obtained from AliExpress for a teardown and ROM dump seems to have custom games rather than the typical gaggle of NES games and fifty ROM hack variations of each.
After a bit of gameplay to demonstrate the various games on the very tiny machine with tiny controls and a tiny 1.8″, 160×128 ST7735 LC display, the device was disassembled. Inside is a fairly decent speaker, the IO board for the controls, and the mainboard with an epoxy blob-covered chip and the SPI EEPROM containing the software. Dumping this  XOR ‘encrypted’ ROM was straightforward, revealing it to be a 4 MB, W23X32-compatible EEPROM.
Continue reading “Reverse Engineering A ‘Tony’ 6502-based Mini Arcade Machine”
