Current Source Mixes Old School And New
At first glance, [RobBest]’s constant current source looks old school. The box is somewhat old-fashioned, featuring switches and binding posts. Most importantly, there’s a large analog meter dominating the front panel. Then you notice the OLED display, and you know something’s up.
The device can source or sink a constant current. In addition, it features a timer that calculates milliamp-hours and automatically turns off when not in use. The brain is a PIC 16F1765, which controls the screen, the buttons, and a few relays. While that might seem an odd choice for the processor, it is actually smart. The device has both a DAC and an ADC, plus an internal op amp. The analog output and a single pass transistor control the current flow, while the two relays flip it between a source and a sink.
Without that op amp, the DAC can’t produce much current. However, by passing it through the onboard amplifier, the output can drive about 100 mA, which is sufficient for this project.
This is a classic circuit, but the addition of a CPU and a display gives it capabilities that would have been very difficult to build back in the day. Want to dive into the theory behind constant current sources?  Or just the practical use of a voltage regulator to make one?
4 thoughts on “Current Source Mixes Old School And New
  1. Furthermore, the firmware is written in JAL, which is an exceptionally efficient and simple to learn language for 8-bit PIC’s. Simplier to learn and use than Arduino, with a ton of well-written libraries as well. And all of that, for free!
  2. “which is an exceptionally efficient”
    How?
    “…simple to learn…”
    Says who? Why?
    “…a ton of well-written libraries …”
    Written by whom and who has declared them “well written”?
    “…Simplier to learn and use than Arduino…”
    Why, and who says so?
    I’m not arguing against anything you said, it might all be true after some fashion. But these are all claims with no substantiation.
    I’m not familiar with JAL, but the AI overlords said it’s a Pascal derivative. So it’s not new or novel.
    Again, I have no ax to grind. Just trying to understand why you’d think this is the greatest thing since sliced bread.
Leave a Reply to PinheadBECancel reply
