Web Dashboard For Zephyr
Over time, web browsers have accumulated a ton of features beyond what anyone from the 90s might have imagined, from an application platform to file management and even to hardware access. While this could be concerning from a certain point of view, it makes it much easier to develop a wide range of tools. All a device really needs to use a browser as a platform is an IP address, and this project brings a web UI dashboard to Zephyr to simplify application development.
Zephyr is a real-time operating system (RTOS) meant for embedded microcontrollers, so having an easy way to access these systems through a web browser can be extremely useful. At its core, this project provides a web server that can run on this operating system as well as a REST API that can be used by clients to communicate with it. For things like blinking lights this is sufficient, but for other things like sensors that update continuously the dashboard can also use WebSocket to update the web page in real time.
The web dashboards that can be built with this tool greatly reduce the effort and complexity needed to interact with Zephyr and the microcontrollers it typically runs on, especially when compared to a serial console or a custom application that might otherwise be built for these systems. If this is your first time hearing about this RTOS we recently featured a microcontroller-based e-reader which uses this OS as a platform.
7 thoughts on “Web Dashboard For Zephyr
  1. Why not use RTEMS which has been around for the last 30 years? It’s definitely going to be more stable, refined and supported on MANY platforms.
      1. The Arduino cores that are based on Zephyr are in beta. The release of Zephyr that they’re derived from is not.
        Arduino has existing cores that run on top of mbed OS, which ARM has abandoned and goes EOL in 2026. They’ve obviously got to move to something else, and they chose Zephyr a few years ago because it was open source, well supported, and compatible with their boards.
        Meanwhile the existing mbed OS arduino cores will continue to work and remain the default.
        No matter what hardware you’re developing for, if you need three-sigma reliability and then choose to deliberately install beta software, you pretty much deserve the consequences.
    1. I don’t have the experience to say how it stacks up to RTEMS, but Zephyr is older and more mature than you might think – it’s the continuation of Virtuoso, which was first developed in the 90’s.
  2. Zephyr man. I work with it everyday. I see the massive utility it provides.
    I’m the kind of person who is fairly unattached to tools and languages.
    And i still hate it.
    1. What are your core gripes with it? I see this sentiment online a lot but don’t see much detail about specifically why people don’t like it.
    2. I’ve bare used it, so my opinion does not hold much weight. But I honestly hate the piles of infrastructure it forces you to use.
      I’d rather run something like freertos over zephyr any day of the week
Leave a Reply to arifynCancel reply
