Breakout Boards For The Blind
Three breakout boards connected with a few wires
Connecting an LED to a battery seems trivial. If you have any knowledge of using breadboards, knowing that red goes with red, and that black goes with black, it’s as easy as tying your shoes. Except there’s one problem: what if you can’t see the difference between red and black? [Tara] had a student who struggled with a problem just like this, so of course, they made a whole suite of breakout boards to the rescue!
Breadboards rely almost completely on the visual cues of rows, columns, and if the part is even in the hole correctly. [Tara] fixed these issues while attempting to keep the usefulness of a breadboard. Using tactile cues rather than the traditional visual, a visually impaired individual can figure out what is positive or negative.
Braille is the obvious choice for general communication of inputs and outputs. Where [Tara]’s ingenuity came in was the method of incorporating Braille into the boards — solder joints. After reading a Hackaday article on solder Braille, [Tara] managed a fitting and efficient method of allowing ease of use.
Currently, the boards are in a prototyping stage; however, if you want to try them out yourself early, let [Tara] know. Others with visual impairments are needed to properly stress test the device. If you are someone who does not struggle with any major visual impairments, it can be hard to put yourself in their shoes. For those empathic (and with VR capabilities) among us, be sure to try it yourself!
4 thoughts on “Breakout Boards For The Blind
  1. This is really cool! I like the variety of cable types for the banana cables for tactile feedback. I wonder about ease of use for things like passive components, like how does a blind person read a resistor color code? I guess using a multimeter with an audio output, but if you have a big bag of resistors that could slow things down. I would think some sort of computer vision tool would make things a lot easier for part ID.
    1. There are lots of options. We use an app called be my eyes, which has an AI module allowing for picture analizing. It is very slow method, but if one doesn’t have sighted assistant, then it is better then nothing.
  2. If you are blind, than all is about good organization. You probably want your rezistors in several boxes sorted by rezistance value. Same approach goes to other parts. Braille labels for boxes might be of help as well.
Leave a Reply to xChrisCancel reply
