Tiny UPS Keeps WiFi Online
For any mission-critical computer system, it’s a good idea to think about how the system will handle power outages. At the very least it’s a good idea to give the computer enough time to gracefully shut down if the power outage will last for an indefinite time. But for extremely critical infrastructure, like our home Wi-Fi, we might consider a more long-term battery backup that can let us get through the longest of power outages.
Part of why this project from [Next Builder] works so well is that most off-the-shelf routers don’t actually use that much energy. Keeping that and a modem online when the power is out only requires a few lithium batteries. To that end, three lithium ion cells are arranged in series to provide the router with between 9 and 12 volts, complete with a battery management system (BMS) to ensure they aren’t over- or under-charged and that they are balanced. The router plugs directly into a barrel jack, eliminating any switching losses from having to use an inverter during battery operation.
While [Next Builder] is a student who lives in an area with frequent interruptions to the electricity supply, this does a good job of keeping him online. If you’re planning for worse or longer outages, a design like this is easily adapted for more batteries provided the correct BMS is used to keep the cells safely charged and regulated. You can also adapt much larger UPS systems to power more of your home’s electrical system, provided you can find enough batteries.
29 thoughts on “Tiny UPS Keeps WiFi Online
    1. A sorta common internet methodology for delimiting user names, which may otherwise just look like random words thrown into a sentence, or otherwise introduce reading speed bumps (read bumps?).
        1. The OP misspoke but had the right idea. They’re used to indicate when the author is clarifying for the reader and not directly quoting or referencing a full proper noun. You see it more often in quotes where the author inserts the name of the something instead of using ‘it, the, we’ etc. Basically just clarifying in a way that makes it clear it was the author’s clarification and not the quote.
          In this case they are using it to clarify that it’s a username referencing a person and not a technical detail or software or technical term because the username has a vague verb sound to it that could be taken out of context. Its just an addition for simplification
      1. The original article left the username blank, and only had []. The article was later edited but without a comment to point that out. Adam was simply pointing out that Bryan forgot to cite his source.
  1. This is just a 3S lithium battery, not a UPS. There’s no voltage regulation, charger or circuitry to transfer between mains and battery power. Lithium ion batteries are also terrible for UPS use since they hate being kept at full charge.
    1. I wonder how hard it would be to DIY a proper one.
      Like plan in an…80% charge? ESP32 voltage monitoring?
      What I don’t understand is how to have it swap over FAST except to have it supplying 12V or 24v or whatever all the time.
      1. Just put a big enough capacitor on the output to supply power while the relay switches over and DC-DC converter starts up. An ESP32 is overkill for monitoring and fairly power hungry. I would probably use a CH32V003 since I have a bunch of them.
        The hard part is keeping the lithium batteries at a specific partial charge level. I would just use an SLA battery on a float charge.
    2. It’s not that hard. For charge look for the LM2596 DC-DC modules on AliExpress. You want the one with 3 trimpots – one for volts, one for current, and the last for voltage cutoff – very important! Add a 3S BMS. Use laptop power supply or USB-C with 20v PD trigger.
      Add another module for power out regulation.
      I converted some old 12v NiCad tools to LiOn with USB-C charge this way, the modules went into the pack. I wish all battery packs were USB-C charged, I have noticed some Chinese tools doing this but haven’t purchased any to see what they do.
      1. Are they using Lithium ion (which generally means NMC) or LFP though? I agree in general that the effect of holding NMC cells at 100% SoC is greatly exagerated but LFP cells are still much happier sitting fully charged, not to mention generally lasting much longer with much higher cycle lives and much less calendar aging
  2. 1) It supplies 9-12V to the router & modem?!?! While I’m not surprised that the router and modem can function off of 9V, this seems rather bold to design this “UPS” without regulating the output to the 12V the devices officially require. I think it would have been much better to add a couple cells to bump up the battery voltage range, then use a simple & efficient buck converter to step that down to a constant 12V output.
    2) If it is determined that the router & modem are happy running off 9-12V, a much simpler design could simply be a small 12v lead acid battery in parallel between the devices and the 12V power supply. The 12V power supply would keep the battery charged to 12V, and supply 12V power to the devices. If a power outage occurs, the 12V power supply will no longer supply power but the battery will – no fancy switching circuitry required!
    The ideal battery is a ubiquitous/universal SLA deep-cycle battery – they are cheap, available in tons of sizes, and there’s a reason why they are used in UPSs, building alarm system backup power, emergency lighting, etc.
  3. One needs to remember that cost/benefit calculations must be biased with a user’s economic means, and that bias can be quite large. In this case one considers the economic resources of a /student/ who also lives in a /village/.
    I can easily imagine they use a battery powered laptop; so the key device is that wifi router as mentioned. And as such a small, cheap, low-power, home-made battery-backed power-pack using a few dollars of components could well save the day despite the clear limitations we can all see.
    There are certainly cycle limits there with lithium being the storage device as pointed out above, however those cells are a few dollars, and it would still be a cheap entry point when their village’s power fails.
    While not a device for most people’s use it’s a nice case design and the components look to be easily obtained and quite cost reasonable.
  4. True inline UPS units with AC input, 5/9/12 V barrel out jacks, USB 5V and even POE have been available for a while; $36 for 20000 mAh claimed; mine cost $30 for 10000 mAh.
    What this design does bring to the table is using an external battery.
  5. All modems I’ve come across have a sizable brick to power them.
    WiFi might be lower power but those modems are not in my experience.
    That thing in the image above would power those very very shortly.
  6. I was thinking about something similar recently. My router runs at about 10W average, each 18650 stores about 3500Mah at 3.7V or about 10Wh, so 3 of them would keep a router alive for 3 hours max, maybe long enough for electricity to return. I considered an old Android phone running as a hot-spot as alternative backup, but it only works as long as the local cell phone masts stay alive (typically 1-2 hours).
  7. I’ve bought some similar solution off of Amazon, after the country-wide blackout last April in Spain. ISP had backup generators, surely, and my home internet connection is done via optic fibre, so in theory I should have been able to keep my Internet working. However, since I had no way of powering my router, I was screwed.
    I love the DIY route showcased here, tough!
  8. Honesty, bought sinusPRO 500e inverter, designed to keep heatingand security systems running, paired it with 65Ah AGM battery and now I have wifi, security cameras and emergency lights running for hours.
  9. This is a rather poor solution,
    I highly recommend to use a proper bms if you use lithium ion cells, with old lead-acid you can get away with a rudimentairy setup like this but if you don’t want to risk to burn your dorm down you should never do this with lithium ion. Also unregulated 9-12v output won’t work for may wifi routers.
    For the cost I would not risk it, a much better solution, 2 cell, buck 12v regulated output, with a proper bms circuit board cost less than €3 on AliExpress (shipping included)
  10. One of the big issues with this is when the power is out its typically a bigger issue that just the modem not having power. Most of the time when I run my generator I will not have wifi even with the modem powered because its an issue with Comcasts end
Leave a Reply to LeftsaltyCancel reply
