Welding Nuts Inside Metal Tubes, Painlessly
[Jer Schmidt] needed a way to put a lot of M8 bolts into a piece of square steel tubing, but just drilling and tapping threads into the thin steel wouldn’t be strong enough. So he figured out a way to reliably weld nuts to the inside of the tube, and his technique works even if the tube is long and the inside isn’t accessible.
Two smaller holes on either side. Weld through the holes. A little grinding results in a smooth top surface.
Essentially, one drills a hole for the bolt, plus two smaller holes on either side. Then one welds the nut to the tubing through those small holes, in a sort of plug weld. A little grinding is all it takes to smooth out the surface, and one is left with a strong threaded hole in a thin-walled tube, using little more than hardware store fasteners.
The technique doesn’t require access to the inside of the tube for the welding part, although getting the nut back there in the first place does require a simple helper tool the nut can slot into. [Jer] makes one with some scrap wood and a table saw, just to show it doesn’t need to be anything fancy.
Another way to put a threaded hole into thin material is to use a rivnut, or rivet nut (sometimes also used to put durable threads into 3D prints) but welding a plain old nut to the inside was far more aligned with what [Jer] needed, and doesn’t rely on any specialty parts or tools.
[Jer]’s upcoming project requires a lot of bolts all the way down long tubing, which is what got him into all of this. Watch it in action in the video below, because [Jer] has definitely worked out the kinks, and he steps through a lot of tips and tricks to make the process painless.
Thanks [paulvdh] for the tip!
37 thoughts on “Welding Nuts Inside Metal Tubes, Painlessly
  1. Obligatory safety reminder – when welding hardware store nuts and bolts be careful of the plating on the part.
    For instance – a lot of hardware is zinc plated, and it can emit quite a toxic gas when welded
    1. On AMZ, Riv Nuts are like 0.10-0.15/per.
      Drill close to size, install in 10 sec, move to the next one.
      Appreciate the tip, but cost of the extra nut, extra drilling, welding sort makes it penny wise-pound foolish.
      Unless you’re really broke, or have the time and equipment….
      1. Think it more depends on what you need – far as I know nobody makes a riv-nut with a tapered seat or a drill bit for them to create that step for a standard nut to have that flush finish to the surface seen here. The rivet part also means you need a fair bit of depth to get the crumple zone in, so a tube like this it could be too thin to allow you to put them in everywhere you want. Also have the mixed material question – you can use this concept with a variety of steel, Aluminium, some copper alloy as long as you can plug ‘weld’ it.
        This is more labour for you, but plenty of reasons you might find this preferable for the end result, and even ignoring the cost element entirely the riveting tool is then potentially another bit of ‘junk’ cluttering your workshop after this one project – I don’t have and likely never will pick one up for that reason alone, as while I have no doubt its a darn handy capability to have I can weld and machine custom nuts etc already, and those tools are already eating up so much of my space!
    1. A bit much for most home shops I’d think, and nowhere near as flexible – as I understand it you really need that big spindle motor drill press/CNC to actually make them work. So only of use where you can bring the work to the machine, which for most of us if even have that suitable machine might be tricky material handling and space wise… No personal experience in putting them in, and it certainly is a cool method though.
      1. For something bigger like the M8 used here, yeah, probably not gonna happen in most home shops, but for smaller stuff you can absolutely manage with a decent drill press. IIRC I did M4 with an AliExpress bit in a 1 1/4 HP old Craftsman drill press.
  2. Seems like it might sometimes be possible to weld bits of wire between nuts, to make a long strip of nuts at the appropriate spacing for the holes. Then slide the strip into the tube and weld the nuts into place. Seems like that might be easier than getting each nut into the right position one by one.
  3. Towards the end he realizes one can just view the inside through the hole right on the opposite side. The same also applies to deburring.
    When drilling through, one side will have more error, but feature the burrs on the outside, and you can circle a hole-sized drift in it.
    A few gentle hammer taps will smash down the burrs.
  4. I had to do this with aluminium box section, so welding not an option, and have a flat surface, so rivnuts not an option.
    I just stuck the nuts on the inside with epoxy, using the bolt to hold them in place while it cured. When the bolt is installed the glue is redundant, so it only needs to be strong enough to hold them in place before assembly.
  5. The idea of adding wings to a nut that is then plug welded in place, nothing jaw dropping, but why wouldn’t you weld the wings on before sticking it in the tube. That way you aren’t welding through a hole.
    Personal I either just make my own square nuts out of some 1″ x 0.25″ flat bar, or just use a flange nut.
    Flat bar works best as I can make it big enough that I’m not cooking the threads when welding.
  6. For threading thin metal, I drill the hole undersized and hammer a tapered punch through to open it to the tap hole size. this creates a “tube” in the metal instead fo just a hole and can give 3-4 threads for engagement. Also, tightening tends to pull the threads tighter.
    This is not as strong as a nut but useful for many applications.
    1. Not a bad trick.
      Here’s a trick I used once; I had to prevent a nut from counter screwing that was fitted in a construction I made, and to achieve that I spot-welded some thin strips of metal to the side of the nut with one of those battery-terminal spot welders. Worked a treat and of course is much less messy than a full welder like in this article’s trick, but was plenty sturdy for its basic use of keeping the nut from rotating.
    1. That.. looks extremely flimsy and their suggestion to unscrew actual installed nuts with it is.. well, nuts.
      But for holding things it might be good.
      I’d buy it from China though, but to each his own.
  7. I call this a “cinch-nut”. For instance, a 1/2″ “cinch-nut; Weld a 1/2″ nut to a 1/2” washer. Drill a hole the diameter of the washer. Place washer in drilled hole with nut side first. Now weld the washer flush with matting surface.
Leave a Reply to Mark OttersonCancel reply
