Recycling PLA And Other Plastic Waste With Compression Molding
After previously trying out low-tech compression molding with a toaster oven and 3D printed molds, [future things] is back with a video that seeks to explore some of the questions raised after the first video. Questions such as how well this method works with HDPE and PLA thermoplastics, whether the flashing could be cut off by the mold and the right temperatures and times to heat the plastic before a charge is ready for inserting into the mold.
In this video the same PHA-based mold is used, but in a three-piece configuration to allow for a more complex shape. This way game tokens could be made for use by the son of the author, which also shows one straightforward and very practical use of this method.
A big change here is that no more metal chopsticks are used to handle the charge, as this was found to cool down the heated plastic too much. Instead the hot charge is handled with fingers and wooden chopsticks, with the plastic heated until it has about the consistency of thick honey. For LDPE this takes about 5-7 minutes at 130°C. After compressing the charge into the mold, about 30 seconds are all it takes for the plastic to cool down enough.
There was a question about the use of mold release spray, but this didn’t seem to cause any issues, so can probably be used safely. As for other plastic types, HDPE works fine too when you heat it up at a slightly higher temperature and don’t mind it being tougher to handle.
Easiest is probably PLA, which would seem unsurprising. Using some chopped-up PLA printing waste it was easy enough to make a few more game tokens, demonstrating that this method is very viable for converting scrap FDM print waste into such items. As noted in the comments by [edmundchao] this method works great too for PETG, using PETG molds, while using a ratcheting clamp for extra pressure instead of just pressing by hand.
4 thoughts on “Recycling PLA And Other Plastic Waste With Compression Molding”
    1. Sure. You’d want a support in the mold or a 3d printed support to suspend it inside the plastic. You also may want to preheat the metal to reduce the thermal shock and resulting shrinkage when the hot plastic hit the metal.
  1. This ‘one off’ process seems a little inefficient for time.
    Is there a problem that I have missed with making it be like this:
    Put a bundle of the silicone cups with plastic in them in the oven, get them all to temp. Then do one at a time into the mold. While the current part is cooling, weigh another batch of plastic, into the cup and into the oven…
