Compact VGA Output Board For The Pi Pico
Many microcontrollers can spit out simple analog video signals if that’s something you desire. However, it normally requires a bit of supporting hardware and, of course, the right connectors to work with your other video equipment. [Arnov Sharma] took that into account when whipping up this neat VGA board for the Raspberry Pi Pico.
VGA output in this case is achieved via judicious use of the Pi Pico’s PIO subsystem, which is perfect for clocking out the signals for red, green, and blue along with HSYNC and VSYNC as needed. The Pico slots right into [Arnov’s] custom PCB, which makes it a cinch to hook everything up. Supporting hardware is minimal, requiring just a few resistors between the Pico and the DE-15 VGA connector. There’s also a nice LM317 regulator on board to supply power to everything. [Arnov] also whipped up a modified version of the VGA library from [Pancrea85], which allows the Pico to output VGA in a way that’s more accepted by more recent TFT displays as well as older CRTs. The system is demoed with a few basic Hello, World programs, as well as a neat recreation of Conway’s Game of Life.
If you want to get a Pi Pico hooked up to a big screen quickly, whipping up a board like this is a great way to go. If you’re wanting something more advanced, though, you could always explore DVI and HDMI on the same platform. Video after the break.
Continue reading “Compact VGA Output Board For The Pi Pico” →
Recycling PLA And Other Plastic Waste With Compression Molding
After previously trying out low-tech compression molding with a toaster oven and 3D printed molds, [future things] is back with a video that seeks to explore some of the questions raised after the first video. Questions such as how well this method works with HDPE and PLA thermoplastics, whether the flashing could be cut off by the mold and the right temperatures and times to heat the plastic before a charge is ready for inserting into the mold.
In this video the same PHA-based mold is used, but in a three-piece configuration to allow for a more complex shape. This way game tokens could be made for use by the son of the author, which also shows one straightforward and very practical use of this method.
A big change here is that no more metal chopsticks are used to handle the charge, as this was found to cool down the heated plastic too much. Instead the hot charge is handled with fingers and wooden chopsticks, with the plastic heated until it has about the consistency of thick honey. For LDPE this takes about 5-7 minutes at 130°C. After compressing the charge into the mold, about 30 seconds are all it takes for the plastic to cool down enough.
There was a question about the use of mold release spray, but this didn’t seem to cause any issues, so can probably be used safely. As for other plastic types, HDPE works fine too when you heat it up at a slightly higher temperature and don’t mind it being tougher to handle.
Easiest is probably PLA, which would seem unsurprising. Using some chopped-up PLA printing waste it was easy enough to make a few more game tokens, demonstrating that this method is very viable for converting scrap FDM print waste into such items. As noted in the comments by [edmundchao] this method works great too for PETG, using PETG molds, while using a ratcheting clamp for extra pressure instead of just pressing by hand.
Continue reading “Recycling PLA And Other Plastic Waste With Compression Molding” →
Can You 3D Print A Pinball Machine That’s Fun To Play?
It seems fair to say that pinball machines are among the most universally loved gaming systems known today, yet the full-sized ones are both very expensive and very large, while even the good quality table-sized ones tend to be on the expensive side. That raises the question of whether a fully 3D printed pinball machine could at all be fun and not just feel like a cheapo toy? A recent video by [Steven] from [3D Printer Academy] on YouTube makes here a compelling argument that it might actually be worth something to consider.
In addition to being fully modular and customizable the most compelling element is probably that the design supports two- and four-player multiplayer. This sees the metal balls leaving at the rear and from there entering the playing field of another player’s machine, which can probably get pretty chaotic.
Unfortunately this is part of a Kickstarter campaign, so you’ll have to either shell out some cash to get access to the print files or DIY your own version. We’d also be remiss to not address the durability concerns of a 100% plastic pinball machine like this, plus the lack of serious heft to compensate for more enthusiastic playing styles.
If you are more into traditional DIY pinball machines, we have covered these as well, along with small screen-based machines, and their miniature brethren for when space is really at a premium.
Continue reading “Can You 3D Print A Pinball Machine That’s Fun To Play?” →
Payphone Tag Is Australia’s New National Sport
Australia’s payphones are an iconic part of the national landscape, even if they’re not as important as they once used to be. However, they’re having a resurgence of late, in part thanks to a new national pastime—the sport of Payphone Tag!
Created by [Alex Allchin], the game is simple. To play, you first sign up on the website and get your emoji and 5-digit PIN. You then go out and find a payphone, dial the Payphone Tag number, and enter your PIN when prompted. This lets you “capture” the phone, raising your score in the game. If a phone is already captured, no matter—just head out there, dial the number, and key in your own PIN to steal it. You can also push your score even higher by capturing three payphones in a triangle on the map to get bonus points.
It’s a fun geospatial game that’s also free to play, because Telstra made payphone calls free back in 2022. It might cost you a bit to get out to some phones, but there are plenty you can reach with the aid of free public transport at the moment, anyway. Protip—at the time of writing, there are a ton of easy captures to be had on Kangaroo Island. It might just cost you a pretty penny to get out there. Have at it!
We’d love to see some stats from Telstra as to whether this is making a dent in overall payphone usage rates. In any case, there were 800 players in the last 7 days and a full 36,640 captures so far, so a lot is happening out there. We fully expect to see this concept spread to other nations in turn, though it might be less attractive in places where you still need to dig out a coin to make a call.
We’ve featured a few payphone hacks over the years. If you’re doing something rad with these telecommunication devices of yesteryear, we’d love to hear about it on the tipsline.
2026 Green Powered Challenge: Supercapacitor Enables High-Power IoT
With all the battery technologies and modern low-current sleep modes in most microcontrollers, running a sensor and microcontroller combo off-grid and far away from any infrastructure is usually not too difficult a task. Often these sorts of systems can go years without maintenance or interaction. But for something that still has to be off-grid but needs to do some amount of work every now and then like actuating a solenoid or quickly turning a servo, these battery-based systems can quickly run out of juice. To solve that problem, [Nelectra] has come up with this high-power capacitor-based IoT system.
Although supercapacitors don’t tend to have the energy density of batteries, they’re perfectly capable of powering short tasks in off-grid situations like this. They’re also typically able to tolerate lower voltages, extreme temperatures, and shock better than most batteries as well. A small solar cell on the top of this device keeps it topped up, and when running in deep sleep mode can hold a charge for up to six days. In more real-world applications supporting sensors, relays, or other actuators, [Nelectra] has found that it can hold a charge for around three days. When a quick burst of power is needed, it can deliver 1.5 A at 9 V or 500 mA at 24 V.
[Nelectra]’s stated goal for this build is to bridge low-power energy harvesting and practical field actuation, enabling maintenance-free systems such as irrigation control and remote switching without batteries, going beyond simple sensor applications while not relying on always-on power from somewhere else. Something like this would work really well in applications like this automated farm, which has already provided some unique solutions to intermittent power and microcontroller applications that need very high reliability.
Hackaday Europe: Last Round Of Speakers, Workshops
If you don’t already have your tickets to Hackaday Europe, pick them up now. The clock is ticking! Today, we’d like to announce our keynote speaker, the remainder of our featured talks, and two more workshops. (And if you want workshop tickets, which always go fast, get those soon!)
Hackaday Europe is super excited to welcome back Hackaday Superfriend [Sprite_tm] to kick off the event with a keynote talk on how he made a retrogaming PC from bare silicon. Don’t miss it.
Continue reading “Hackaday Europe: Last Round Of Speakers, Workshops” →
A Tube Amplifier That’s Oven Ready
The problem with tube based audio is that it has so often been hijacked by people for whom the bragging rights of having a tube amplifier outweigh the benefits, or the sheer fun of building the thing. [Bettina Neumryr] makes a speciality of building projects featured in old electronics magazines, and her latest, a tube amplifier from 1955, is a fantastic antidote to the gold-plated silliness of audiophile tube amplifiers.
Design wise it’s relatively straightforward, with a preamplifier before a two-tube transformerless splitter circuit driving a push-pull output. She dives into the circuit a little, noting its feedback circuit to the cathode of the first splitter tube. There’s an accompanying power supply, a classic tube rectifier design that incorporates a hefty low-pass filter with a giant choke.
We particularly like her choice of chassis — while it’s possible to pay silly money for a tube chassis in 2026 she’s taken a much more down to earth approach with a pair of baking trays. We’re being honest here, they look surprisingly good. Component choices are limited by what’s available so most parts come from the junk box including the output transformer which causes her issues later. There’s a lot of mumbo-jumbo about tube amplifier layout, and she wisely sidesteps some of it.
The result after a few mishaps and a bit of unintended oscillation, is an amp which shows promise, but has distortion due to that transformer. We think she’ll have no problems sourcing a better one, which should bring that distortion figure into the acceptable range. You can watch the whole video below the break, and if that’s got you hooked, you can see one of our own youthful follies.
Continue reading “A Tube Amplifier That’s Oven Ready” →
