Hacking Amazon Echo Show 8 3rd Gen Via UART And EMMC
Even with Amazon’s Echo Show devices running Linux in the form of the Android-derived FireOS, using them for non-Amazon approved purposes can be a chore at best. In the case of the Echo Show 8 even simple workarounds using ADB and the bootloader have been locked-down, requiring more drastic measures. Here [Vowed] over at the XDA forums shows off one such hack, involving directly tapping into the device’s eMMC.
Suffice it to say that this is not a hack for the faint of heart, with even the iFixit teardown guide for this device being rather daunting. Even after you get access to the mainboard, you still have to remove or cut open the metal can that covers the eMMC, so that you can unleash an eMMC programmer on it. It’s best to make sure to make a backup image of the original contents too, just in case you have to restore things.
With the shield out of the way you can solder fine wires to pads that connect to the eMMC to program it. You also have to solder wires to pads for the UART, though if you’re fancy you can also create a custom pogo pin adapter. With a serial connection established to the original firmware you can then enable features like ADB, and courtesy of the connected eMMC adapter it’s possible to directly alter system files to make rooting as easy as possible.
In addition to rooting the system you can also do a straight replacement of the eMMC contents, such as the demonstrated Debian installation. Even if not the most easy of mods, it’s good to see that it’s possible to repurpose these devices.
(Top image: Amazon Echo Show 8 3rd generation mainboard. Credit: iFixit, CC BY-NC-SA 3.0.)
8 thoughts on “Hacking Amazon Echo Show 8 3rd Gen Via UART And EMMC”
  1. The teardown isn’t really that daunting (and rated “Moderate”). They go on a LONG digression about how to remove the speakers, but those are in the rear shell and if you’re only looking to get to the motherboard you don’t have to deal with any of that. So steps 5-10 are totally unnecessary.
    The only other major hurdle is that they use a ton of flimsy ribbon cables with very little slack, so it’s careful work, and the disassembly is slow going, I’m sure.
    1. For sure, it’s definitely easier than the average smartphone disassembly these days, though even as someone who has done said modern smartphone dis- and reassembly I’d schedule in at least an afternoon for the disassembly.
      That said, if you’re looking to solder tiny wires to pads on the PCB you’re probably already in the group of people who’d do such disassembly for relaxation :)
