Using Your Own RBMK Reactor Control Center At Home
To give people the most intimate RBMK experience, the [Chornobyl Family] has been working tirelessly at not only replicating the original RBMK reactor control room and its SKALA industrial control system’s controls, but also to create a version that you could tinker with at home if you ever fancied getting your own RBMK operator license. This starts with the operator console, with its use demonstrated in a recent video including a range of common commands.
In this video the entering of codes on the console to interact with the system is detailed, including the logic behind it. In the absence of large displays to display many parameters and such, this way the operator could ‘talk’ with the control system, including obtaining current sensors readings and the setting and changing of setpoints. From the same console you can also select and run programs, which is useful for automating tasks, like monitoring coolant flows.
In the second video not only the construction of the control panel is covered, but also a visual representation of the simulated reactor core which is displayed on a connected monitor. Although not a part of the original SKALA system as such, a much larger version existed as a wall-sized physical version inside the control room, so it’s definitely more home-simulator friendly.
We previously covered this SKALA system that controls RBMK reactors, as well as the 1990s modernization of the Chornobyl Nuclear Power Plant.
8 thoughts on “Using Your Own RBMK Reactor Control Center At Home”
  1. Cool, but no Chornobyl reactor simulation is complete without a headstrong person in charge who won’t listen to reason. Bravado is a major ingredient in many nuclear accidents, such as the Demon Core accidents, and also the MSRE accident, with MSRE being run after it had already melted down, and the Demon Core, what can you say about someone modulating criticality–with a flat-bladed screwdriver.
  2. Imagine the world if Chernobyl didn’t happen. Pity the ordinary people who died, but the accident combined with the war in Afghanistan really helped USSR burn through its financial reserves.
    1. Good point. The same can be said about early 21th century, I guess.
      Who knows what the world would look like now if certain things hadn’t happened
      and people hadn’t been given a lesson which changed their minds.
      “What if..” is perhaps one of the most fascinating questions in history.
