Continuing their reverse-engineering of Intel’s 8087 FPU, [Ken Shirriff] and friends took a look at one of the trigonometric functions, specifically FPTAN. The most exciting part with such reverse-engineering is probably figuring out which algorithm was used in the implementation, while trying to determine the reasoning behind the final hardware design.
If you’re running a simple MCU or MPU like the 6502 or Z80 without hardware functions you’d likely use an algorithm such as CORDIC or similar, as this requires only basic hardware features like addition, subtraction, bitshift, and look-up tables. One can also use polynomial approximation if there’s hardware support for a potential speed-up, or as is the case in the 8087, create a hybrid approach that targets speed and accuracy.
In the article the exact implementation to get to 64 bits of accuracy is detailed, starting with the 16 bits calculated using CORDIC before switching to the Padé approximant technique involving the ratio of two polynomials. Since after calculating the brunt of the final value with CORDIC the remainder is a fairly small value, this polynomial approximation is not just very accurate but also fast.
This approach allows the FPTAN and similar trigonometric functions in this FPU to hit a very high level of accuracy and not require the look-up table sizes and additional time required to work through the remaining bits with CORDIC. For those who want to see the full algorithm Intel’s engineers used, [Ken] has the full microcode listing with comments in the article as well.
As for the exact speed-up from this approach, [Ken] calculates for one value that FPTAN would spend 33% on CORDIC pseudo-division, 47% on CORDIC pseudo-multiplication and a mere 15% on the polynomial approximation along with about 5% overhead.
With the Pentium series of CPUs Intel moved completely away from CORDIC, as it’s clear that as accurate as it may be, it’s hard to scale to a significant number of bits without incurring significant time penalties. With the introduction of SIMD instructions the x87 ISA has further seen its functionality reduced, but this analysis shows once again why the 8087 made such an impact when it was released.
8087 family calculates to 80 bits of precision not 64. It truncates or rounds to a double
80-bit floats use a 64-bit mantissa, the rest is reserved for the exponent. So yes, the actual precision is only 64-bits. Look the extended precision floating point format and how it uses the bits associated with each part.
Doubles are 64-bits with a 53-bit precision, in case you care.
I love how the article ends:
“AI statement: Despite the presence of the em dash, no AI was used in the writing of this article (details).”
Hahaha, so it seems like there are sensible people still left around :D.
This is wrong.
Intel’s version here is 2x-3x slower than it needs to be because it performs cordic forward and then again backwards, when a forward pass with a larger register size (say 128-bit or 256-bit integers) would give the same result. It’s overcomplicated.
It’s likely still used for instructions like FPATAN btw, they’re just completely in microcode nowadays.
I think this is a mistake, but the people using those instructions probably do not care about the speed that much. Using 80-bit floats is rare because it involves the legacy FPU and isn’t very portable.
