Before transistor-transistor logic (TTL) took over, diode-transistor logic (DTL) was a common sight especially in pre-IC circuits where it was a major improvement over resistor-transistor logic (RTL). That said, it’s rare to see DTL used in ICs considering how e.g. TI’s 5400 and 7400 series set the trend in the 1960s. This makes the Signetics ST680a quad-NAND gate DTL DIP IC that [Ken Shirriff] ogled recently a bit of a treat.
This was also one of the earliest ICs to use the then brand new plastic dual in-line package (PDIP) for modular convenience, even if [Ken] was none too happy about as unlike ceramic DIP, PDIP requires more extreme methods to decap to access the die for reverse-engineering.
Overall, TTL is faster and less power-hungry than DTL, but it took a while to work out its issues, including noise immunity and fan-in/out issues. Until then alternatives like DTL still made sense as a well-understood and mature technology. In the article an example is provided of how a DTL NAND gate as used in this IC works, which is really quite simple in how it uses multiple diodes to sum the inputs, which subsequently drives the transistors.
We’d like to thank [CuriousMarc] for finding this IC in his strategic reserve of unknown ICs and for doing the initial decapping using hot air, as well as [Ken] for doing the analysis and documenting of this fascinating glimpse into early semiconductor logic history.
Awareness of DTL has come in handy for me a couple of times. I was able to eliminate a glue logic IC a couple of times without adding another line item to the bill of materials.
Back in Uni, I got dinged on a lab for this. The stockroom inventory was the specified limit, and the I needed an extra input on a TTL NAND, and there wasn’t a four input on hte inventory list. IIRC, the line cost for the two Shottkey diodes was less than half the line cost for the and to double up an input, and the other gates in the device would be wasted (the “correct” solution). It also left more room in the power budget.
I thought I had learned the lesson from a previous lab where the “correct” solution was to use an IC with three input gates (7411, if I recall), and tie an unused input on the gates that needed to be two input gates. The argument was lower IC count (valid… it reduced the cost a few cents, despite the line price being higher than the IC’s I spec’d) and left more meat on the power budget. I missed that on the inventory list, so ate my crow and moved on.
Spent an afternoon in the lab proving to the lab supervisor that my solution with the diodes met all requirements, and was faster and lower cost than the specified solution, including meeting all worst case threshold values. In the end, he said it didn’t matter, since we were supposed to do it using only logic ICs, which was no where in the specification.
It still bugs me….
You have every right to be bugged.
YOu where smarten then him and he was to proud to admit it.
Signetics may have been founded to only make ICs, but they were so impressed by the quality of the DMOS transistors that made up one of their IC processes that they made those transistors available as single devices, the SD211 series. For many years they were the best analog switching transistors available, although expensive.
When my dad passed away, i inherited his collection of fairchild DTL ics. I built a full adder out of 949 quad nands to remember him since he taught my brother and I counting, adding, and binary search when we were very young.
