When you think about nuclear radiation, you often think about power plants, but it turns out there’s radioactive stuff all over the place: smoke detectors, granite counters, bananas, and potatoes can all be mildly radioactive. Even some old tape dispensers. But those are all puny sources.
Radon is a colorless, odorless gas that is heavier than air. It is a byproduct of uranium decay, amonth other pathways, decays by emitting an alpha particle, and has a half-life of just about four days. As a gas, it escapes from rocks or soil. Usually, there isn’t much of it, so it vents harmlessly to the atmosphere. But it can easily get trapped in a house and accumulate. You might think your house is solid, but there are plenty of cracks, joints, and pipes where gas can weasel through, especially if your inside pressure is slightly lower than the pressure in the soil below, which is common.
As the radon decays, it can produce more radioactive material, including tiny amounts of polonium. With or without dust particles, these tiny bits of radioactive material can go airborne and end up in your lungs. There, they can further decay, and alpha particles damage cells and DNA. According to the EPA, radon exposure is the second leading cause of lung cancer in the United States, next to smoking.
Not So Speedy
If you get enough carbon monoxide in your home, you probably won’t see the next sunrise. But radon works very slowly. It is odorless and colorless. You won’t show any general symptoms to warn you that you might get lung cancer.
The effect can take years or decades. Of course, you can also have a house that has very little radon. However, nearly all homes have some radon. The EPA estimates that about 7% of homes have elevated radon levels.
Some areas are more prone to radon than others, but even if your area has low risk, there’s no guarantee that your house is safe. If you are lucky enough to not have a radon problem, you have nothing to worry about. But how do you know? Like anything, you need to test.
Testing
The simplest radon tests use activated charcoal to absorb radon from the air. After exposure for a few days, you mail the charcoal to a laboratory, which measures its radioactivity. These kits typically cost very little (well under $50). Like any radon detector, you want to put it on the lowest inhabited part of the house (that is, the basement or ground floor). The kit will give you exact placement details (usually a few feet up in a draft-free area). These tests are short-term and are typically exposed to the air for only a few days.
These charcoal pouches are adequate for quick screening tests. However, longer tests will probably require different techniques. To better assess long-term exposure risk, you’ll want a test that runs for more than 90 days.
Long-term detectors often use a special plastic film. Alpha particles striking the film leave microscopic damage tracks. After exposure, a laboratory chemically etches the film and counts the tracks to estimate radon concentration.
Naturally, there are electronic options, too. Continuous radon monitors use radiation detectors, often based on ionization or semiconductor sensing, to measure radon over time. These are particularly interesting because they reveal the considerable fluctuations that a short-term test can miss. Besides, radon levels also change with weather, season, ventilation, and even how the heating system operates. A single measurement doesn’t necessarily tell the whole story.
Too Much?
Radon is normally measured in picocuries per liter (pCi/L). One picocurie corresponds to approximately 0.037 radioactive decays per second, so a concentration of 4 pCi/L represents roughly 148 decays per second per cubic meter of air.
The EPA recommends mitigation when the long-term concentration reaches 4 pCi/L (approximately 148 Bq/m3), and suggests considering remediation even between 2 and 4 pCi/L. That isn’t a sharp safety boundary. Radiation risk increases with exposure, and no radon concentration is known to be safe.
Remediation
Before you go and try to make your house totally airtight, you should know that is probably not going to work. Instead, if you decide to act, you’ll want a sub-slab depressurization system like the one in the adjacent photo. This is little more than a blower fan that pulls air from under the slab and vents it out a tall pipe.
The fan is usually outside or in an attic. The exhaust has to be above the roofline. You want it far from other openings like windows so radon doesn’t get in. The low pressure tends to vent the soil gases out the exhaust instead of into the house. Once you install it, you should do more testing to see that it was effective. In fact, you should periodically retest and inspect the blower, too. The EPA suggests testing every two years.
As you can see in the Irish EPA video below, you can also increase ventilation under the house in other ways. It all depends on how much of a problem you have and exactly how your house is built.
DIY?
If you are reasonably handy, you could install it yourself, although there are a few nuances that may cause you to turn to a professional. Assuming you have a typical slab, you’ll need to drill a roughly 5-inch hole through the slab and create a pit. A PVC pipe is placed in the pit with a seal. A special “radon fan” pulls the suction in that pipe and discharges it into another PVC pipe. There’s also a manometer to show the negative pressure. This tells you the fan is producing suction. It doesn’t, of course, tell you that you’ve actually reduced the radon level. That will take more testing.
Depending on your foundation, though, you need to be careful. You want to produce negative pressure everywhere, not just at the location of the pit. For dense soil, you may need more than one suction point. You also need the right fan and to ensure nothing leaks back into the house.
The good news is that a typical install isn’t terribly expensive, often around $1,000 or so. Also, depending on your situation, you may legally need a pro to at least certify that your system is working, or they may prevent you from doing it yourself. Check your local laws.
While a pro may be better suited to mitigating radon, you can do your own testing in your preferred style.
And then you come to Germany, and find them using Radon as a treatment for pain and all kinds of other stuff.
https://acuradon.de/en/
Regular German health insurance doesn’t pay for it, so it seems to be some kind of snake oil stuff.
There used to be radon spas in the US as well back in the late 1800s. There are a couple mine exploring youtube channels that take you through them.
Radon does act as an anesthesia, as does xenon above it on the periodic table, but inhaling radioactive isotopes that decay into stable heavy metals isn’t good for you so we use prescription NSAIDs or opiods for chronic pain these days.
Why would insurance pay for sneak oil? If you want medical treatment, pay for it. That’s how it worked for the last 4000 years.
That’s what I said. Insurance won’t pay for it, which means it is snake oil. If it were safe and effective, it would be on the approved treatments list that insurance will pay for.
https://topkur.de/hotel/radium-palace
They do have radon spas, and the CZ health insurance can pay for it.
Private insurance in Germany will pay for such stuff, too. Doesn’t change the fact that it is snake oil. You paextra for private insurance, for which they give you extra services. One of those services is paying for things that people want to be paid but which aren’t known to be safe or effective.
I’m not looking for a place to do it.
I’m pointing out that people do crazy shit because crazy people tell them it will help, when every one else is not doing the crazy shit because it will kill you.
Whilst I would rather be dosed with most other radioisotopes prior to accepting Radon as a “treatment”, I genuinely believe that radiotherapy has applications outside of cancer & even within the realm pain relief.
I’m not sure how effective the low dose Xray beam therapy they use at the moment is, as the studies seem split, but there is more evidence in support appearing as of late. Nevertheless, selective damage via a precise beam is essentially a very sharp, very small & very long scalpel, so it’s seemingly how the tool is used that is of most importance. Sadly, it’s just incredibly hard measuring the effects, when very few places offer it, it scares most off & being low dose & all, it’s not easy to determine what’s placebo & what’s therapy.
Perhaps being a cobalt-60 acupuncturist has been my calling all along :’)
“Regular German health insurance doesn’t pay for it, so it seems to be some kind of snake oil stuff”
How do you call alternative medicine that is proven safe and effective?
Medicine.
Well, it’s proven not safe, long-term.
If your house already has a drainage sump this is another ideal place to draw radon from as you benefit from the drainage tile running around the perimeter of your house to vent from. You can install a sealed lid on your sump basin and draw air from it using a radon fan.
My house was around 8 pCi/L, but measured over 40 in the closet where the sump pit was located. I initially tried passively venting the pit outside, but found that barely made a dent. Adding a radon fan dropped the levels to regularly below 1.
If you plan to buy or sell a home, be aware that radon testing and mitigation may be REQUIRED. Talk to your real estate professional.
https://thelegalguide.org/radon-testing-when-home-is-it-required-why-it-matters/
The really fun part, though, is telling your new neighbors that the reason basements are so rare in your area is not, in fact, the water table. (Or rather, seeing their faces as you explain.)
I mentioned to my neighbor about the radon levels in my home and suggested he should test his. “I’ve been here 30 years and it hasn’t killed me yet,” was the curt response I got after I explained to him why radon was an issue. Some just can’t be helped.
“New fear unlocked”, as the “kids” would say these days
It’s ridiculous that life exists on earth at all, considering even a leaking rock gas wants to mangle your DNA.
Naw.. it’s good for you. We call it the Kennedy-Nietzsche doctrine. (Like road kill, it doesn’t kill you, it makes you stronger.)
nice canary btw
Radiation on earth used to be much stronger than it is today. Its natural and helps drive evolution.
Well your immune system normally handles random cancer cells that naturally pop up. It’s when your immune system weakens (like in old age) that you have a higher chance of some slipping through. Or, if your exposure to carcinogens like radiation or cigarette smoke is too excessive, your immune system can’t keep up. In severe radiation exposure incidents your immune system actually gets killed off itself.
That’s a bt too simplified. Cancer cells “mask” themsleves in multiple way, to avoid being terminated by the immune system.
I bet that isn’t true “in general”, it’s just the ones that haven’t masked that survive and grow into tumours. Probably the vast majority get picked off.
Hey, life was initially intended for large bodies of water…
You can mitigate the effects of radon daughter products by trapping them with electrostatics. They provide the bulk of your exposure. It isn’t a endorsed radon mitigation strategy as it doesn’t protect you rom the radon itself.
Here is an experiment you can do at home
https://m.youtube.com/watch?v=Hn-dfiH5z10
You can also just ventilate the basement without punching holes through the foundation. Cycling fresh air in from outside is highly effective and you can get significant reductions in radon concentration with quite modest fans.
You actually really want to make sure that any open holes (e.g. sump) are closed as well, otherwise you can actually raise it.
Yep, an ERV/HRV is an excellent choice for low levels, or in addition to a mitigation system. You also want to ensure any obvious cracks or penetrations are sealed, and avoid negative air pressure in the house (It’s fun to look at the manometer when the house fan is turned on…)
Radon is always one of the fun things to point out to people with a cloud chamber, since alpha particles are dramatic. I grew up over an apparently very reactive hotspot (highest in the entire state, wee!) and it was easy to explain to my parents when I was older by just them watching it.
If it would just keep–it would make good fuel for ion engines
https://kb.osu.edu/server/api/core/bitstreams/97c76c7e-c4b4-5b00-bbdf-f15da043f7a7/content
https://merrywidowhealthmine.com/
Radon mines are alive and well it the US.
Interesting thing I learned from a local group that was focusing on radon: larger apartment buildings, higher radon levels are observed (unsurprisingly) in underground parkades, but also in the highest levels – penthouse suites. Lower radon levels are typically seen at building levels between these. The radon comes from the ground and then air is pushed and convects up the elevator shafts.
“However, nearly all homes have some radon.” I have a hard time believing this, unless you mean in trace amounts such that you could also say nearly all homes have some traces of everything from arsenic to zirconium. The radiation level inside my house is very low and no different inside or outside, whereas the co2 levels can be measurably elevated compared to outside. And I have a couple antiques that used radium paint, too, so maybe it just escapes too easily to really notice in houses that aren’t well sealed and don’t have a basement.
It depends a lot on where you live. Houses in .nl have an average Radon level of 0.5pC/l, without any special measures. However, most of .nl is drained swampland, and swamp cointains hardly any rock, while foundations on drained swampland need to be ventilated in order to keep moisture in the house under control. The radon is removed with the moisture.
“According to the EPA, radon exposure is the second leading cause of lung cancer in the United States, next to smoking.” – I’ve always questioned how they determined this. Apart from the uranium mining studies, the research on radon exposure is pretty lacking.
We had a venting system installed, because the levels were insanely high. Continuous testing meters show that the levels in the buried area of the basement are consistently around 2 (probably higher in Winter), while the area of the downstairs where there is windows present still registers around 2-2.43 or sometimes close to 3 in the Winter. This is better than 20, but still somewhat concerning, given that we have a venting system.
I generally wear an N95 mask if I’m going to be spending extended time in those places, since I have read that it blocks most (if not all) of the solid radioactive particles.
