There’s perhaps no more iconic video game than Tetris. First built for the Soviet Elektronika 60 computer, then ported to the IBM PC and, most famously, the NES and Game Boy, Tetris is available on essentially every computer platform, and it has an extremely competitive scene. It’s also adaptable to all kinds of displays. [Daniele Tartaglia] built this large version using special 3D-printed blocks and addressable LED strips, showing just how easy it is to build Tetris into a wide variety of environments.
The display is built on a wood base, with the LED strips laid down along it and with the wires connecting them running through the back. Each cell on the display uses 3D-printed diffuser cubes, printed in white to help diffuse each LED’s light, with a black layer between each to prevent light from bleeding into adjacent cubes. A smaller diffuser panel is added to the top, which shows the next piece and the score. The cover at the top is a custom graphic, and the entire build is run from an ESP32 microcontroller. There are a number of other games, such as Snake, that can be selected with a companion app, and the display can also be used as a clock or for ambiance.
Another part of the build is [Daniele]’s custom controller called RetroJoy, which is a wireless arcade-style controller with a joystick and buttons. It’s optional, though, as the games can be played on a smartphone through the app, but it’s also an interesting build he hopes to use in upcoming projects. Of course, [Daniele] is using a lot of high-dollar tools to build this project, like a UV printer, laser cutter, and a multi-color 3D printer. Also, the plans aren’t free, but this should give anyone thinking about a similar Tetris-style build a few ideas to work from, even if they choose not to buy the plans or are lacking in expensive tools. One of our favorites from the past was one built into a second-story window that let any passersby in on the fun.
