This Week In Security: Owncloud, NXP, 0-Days, And Fingerprints
We’re back! And while the column took a week off for Thanksgiving, the security world didn’t. The most pressing news is an issue in Owncloud, that is already under active exploitation.
The problem is a library that can be convinced to call phpinfo() and include the results in the page response. That function reveals a lot of information about the system Owncloud is running on, including environment variables. In something like a Docker deployment, those environment variables may contain system secrets like admin username and password among others.
Now, there is a bit of a wrinkle here. There is a public exploit, and according to research done by Greynoise Labs, that exploit does not actually work against default installs. This seems to describe the active exploitation attempts, but the researcher that originally found the issue has stated that there is a non-public exploit that does work on default installs. Stay tuned for this other shoe to drop, and update your Owncloud installs if you have them. Continue reading “This Week In Security: Owncloud, NXP, 0-Days, And Fingerprints”
This Week In Security: Magic Packets, GPU.zip, And Enter The Sandman
Leading out the news this week is a report of “BlackTech”, an Advanced Persistent Threat (APT) group that appears to be based out of China, that has been installing malicious firmware on routers around the world. This firmware has been found primarily on Cisco devices, and Cisco has released a statement clarifying their complete innocence and lack of liability in the matter.
It seems that this attack only works on older Cisco routers, and the pattern is to log in with stolen or guessed credentials, revert the firmware to a yet older version, and then replace it with a malicious boot image. But the real fun here is the “magic packets”, a TCP or UDP packet filled with random data that triggers an action, like enabling that SSH backdoor service. That idea sounds remarkable similar to Fwknop, a project I worked on many years ago. It would be sort of surreal to find some of my code show up in an APT.
Don’t Look Now, But Is Your GPU Leaking Pixels
There’s a bit debate on who’s fault this one is, as well as how practical of an attack it is, but the idea is certainly interesting. Compression has some interesting system side effects, and it’s possible for a program with access to some system analytics to work out the state of that compression. The first quirk being leveraged here is that GPU accelerated applications like a web browser use compression to stream the screen view from the CPU to the GPU. But normally, that’s way too many pixels and colors to try to sort out just by watching the CPU and ram power usage.
And that brings us to the second quirk, that in Chrome, one web page can load a second in an iframe, and then render CSS filters on top of the iframe. This filter ability is then used to convert the page to black and white tiles, and then transform the white tiles into a hard-to-compress pattern, while leaving the black ones alone. With that in place, it’s possible for the outer web page to slowly recreate the graphical view of the iframe, leaking information that is displayed on the page.
And this explains why this isn’t the most practical of attacks, as it not only requires opening a malicious page to host the attack, it also makes some very obvious graphical changes to the screen. Not to mention taking at least 30 minutes of data leaking to recreate a username displayed on the Wikipedia page. What it lacks in practicality, this approach makes up for in cleverness and creativity, though. The attack goes by the GPU.zip moniker, and the full PDF is available. Continue reading “This Week In Security: Magic Packets, GPU.zip, And Enter The Sandman”
This Week In Security: WebP, Cavium, Gitlab, And Asahi Lina
Last week we covered the latest 0-day from NSO group, BLASTPASS. There’s more details about exactly how that works, and a bit of a worrying revelation for Android users. One of the vulnerabilities used was CVE-2023-41064, a buffer overflow in the ImageIO library. The details have not been confirmed, but the timing suggests that this is the same bug as CVE-2023-4863, a Webp 0-day flaw in Chrome that is known to be exploited in the wild.
The problem seems to be an Out Of Bounds write in the BuildHuffmanTable() function of libwebp. And to understand that, we have to understand libwebp does, and what a Huffman Table has to do with it. The first is easy. Webp is Google’s pet image format, potentially replacing JPEG, PNG, and GIF. It supports lossy and lossless compression, and the compression format for lossless images uses Huffman coding among other techniques. And hence, we have a Huffman table, a building block in the image compression and decompression.
What’s particularly fun about this compression technique is that the image includes not just Huffman compressed data, but also a table of statistical data needed for decompression. The table is rather large, so it gets Huffman compressed too. It turns out, there can be multiple layers of this compression format, which makes the vulnerability particularly challenging to reverse-engineer. The vulnerability is when the pre-allocated buffer isn’t big enough to hold one of these decompressed Huffman tables, and it turns out that the way to do that is to make maximum-size tables for the outer layers, and then malform the last one. In this configuration, it can write out of bounds before the final consistency check.
An interesting note is that as one of Google’s C libraries, this is an extensively fuzzed codebase. While fuzzing and code coverage are both great, neither is guaranteed to find vulnerabilities, particularly well hidden ones like this one. And on that note, this vulnerability is present in Android, and the fix is likely going to wait til the October security update. And who knows where else this bug is lurking. Continue reading “This Week In Security: WebP, Cavium, Gitlab, And Asahi Lina”
This Week In Security: Spandex Tempest, Supply Chain Chain, And NTP
Microsoft’s Threat Intelligence group has announced a new naming scheme for threat actors. It sounds great, naming groups after weather phenomenon, based on the groups motivations or nation of origin. Then each discreet group is given an additional adjective. That’s where things get interesting.
It seems like the adjectives were chosen at random, giving rise for some suitably impressive names, like Ghost Blizzard, Ruby Sleet, or Granite Typhoon. Some of the other names sound like they should be desserts: Caramel Tsunami, Peach Sandstorm, Aqua Blizzard, or Raspberry Typhoon. But then there the really special names, like Wine Tempest and Zigzag Hail. But the absolute winner is Spandex Tempest. No word yet on whether researchers managed to keep a straight face when approving that name.
Chrome 0-day Double
A pair of Chrome browser releases have been minted in the past week, both to address vulnerabilities that are actively being exploited. Up first was CVE-2022-2033, type confusion in the V8 JS engine. That flaw was reported by Google’s Threat Analysis Group, presumably discovered in the wild, and the fix was pushed as stable on the 14th.
Then, on th 18th, yet another released rolled out to fix CVE-2023-2136, also reported by the TAG, also being exploited in the wild. It seems likely that both of these 0-days were found in the same exploitation campaign. We look forward to hearing the details on this one. Continue reading “This Week In Security: Spandex Tempest, Supply Chain Chain, And NTP”
This Week In Security: Exchange 0-day, Doppelgangers, And Python Gets Bit In The TAR
According to researchers at GTSC, there’s an unpatched 0-day being used in-the-wild to exploit fully patched Microsoft Exchange servers. When they found one compromised server, they made the report to Microsoft through ZDI, but upon finding multiple Exchange servers compromised, they’re sounding the alarm for everyone. It looks like it’s an attack similar to ProxyShell, in that it uses the auto-discover endpoint as a starting point. They suspect it’s a Chinese group that’s using the exploit, based on some of the indicators found in the webshell that gets installed.
There is a temporary mitigation, adding a URL-based request block on the string .*autodiscover\.json.*\@.*Powershell.. The exact details are available in the post. If you’re running Exchange with IIS, this should probably get added to your system right now. Next, use either the automated tool, or run the PowerShell one-liner to detect compromise: Get-ChildItem -Recurse -Path -Filter "*.log" | Select-String -Pattern 'powershell.*autodiscover\.json.*\@.*200. This one has the potential to be another really nasty problem, and may be wormable. As of the time of writing, this is an outstanding, unpatched problem in Microsoft Exchange. Come back and finish the rest of this article after you’ve safed up your systems.
Continue reading “This Week In Security: Exchange 0-day, Doppelgangers, And Python Gets Bit In The TAR”
This Week In Security: Unicode Strikes, NPM Again, And First Steps To PS5 Crack
Maybe we really were better off with ASCII. Back in my day, we had space for 256 characters, didn’t even use 128 of them, and we took what we got. Unicode opened up computers to the languages of the world, but also opened an invisible backdoor. This is a similar technique to last week’s Trojan Source story. While Trojan Source used right-to-left encoding to manipulate benign-looking code, this hack from Certitude uses Unicode characters that appear to be whitespace, but are recognized as valid variable names.
const { timeout,ㅤ} = req.query;
Is actually:
const { timeout,\u3164} = req.query;
The extra comma might give you a clue that something is up, but unless you’re very familiar with a language, you might dismiss it as a syntax quirk and move on. Using the same trick again allows the hidden malicious code to be included on a list of commands to run, making a hard-to-spot backdoor.
The second trick is to use “confusable” characters like ǃ, U+01C3. It looks like a normal exclamation mark, so you wouldn’t bat an eye at if(environmentǃ=ENV_PROD){, but in this case, environmentǃ is a new variable. Anything in this development-only block of code is actually always enabled — imagine the chaos that could cause.
Neither of these are ground-breaking vulnerabilities, but they are definitely techniques to be wary of. The authors suggest that a project could mitigate these Unicode techniques by simply restricting their source code to containing only ASCII characters. It’s not a good solution, but it’s a solution. Continue reading “This Week In Security: Unicode Strikes, NPM Again, And First Steps To PS5 Crack”
This Week In Security: NSO, Print Spooler, And A Mysterious Decryptor
The NSO Group has been in the news again recently, with multiple stories reporting on their Pegasus spyware product. The research and reporting spearheaded by Amnesty International is collectively known as “The Pegasus project”. This project made waves on the 18th, when multiple news outlets reported on a list of 50,000 phone numbers that are reported as “potential surveillance targets.” There are plenty of interesting people to be found on this list, like 14 heads of state and many journalists.
There are plenty of questions, too. Like what exactly is this list, and where did it come from? Amnesty international has pointed out that it is not a list of people actively being targeted. They’ve reported that of the devices associated with an entry on the list that they have been able to check, roughly 50% have shown signs of Pegasus spyware. The Guardian was part of the initial coordinated release, and has some impressive non-details to add:
The presence of a phone number in the data does not reveal whether a device was infected with Pegasus or subject to an attempted hack. However, the consortium believes the data is indicative of the potential targets NSO’s government clients identified in advance of possible surveillance attempts.
Amazon’s AWS was named as part of the C&C structure of Pegasus, and in response, they have pulled the plug on accounts linked to NSO. For their part, NSO denies the validity of the list altogether. Continue reading “This Week In Security: NSO, Print Spooler, And A Mysterious Decryptor”
