Finally, a brake for your long board
Long Board Takes A Brake
Long boards are awesome. They feel like your surfing on concrete — amazing for hilly areas where you can coast around forever. The weird thing is, none of them come with brakes standard… Even though when you’re going down a hill you can easily hit 30-40mph! [Marius] decided to fix this, so he built his own 3D printed brake system for his Onda long board.
He designed the system in 3Ds Max and 3D printed the parts in PLA using his Printrbot Metal Simple (check out our review here). It uses an off the shelf bicycle brake pad, and brake cable as well as a few elastic bands. Currently only one wheel brakes, but it seems to be enough to slow you down — though he might mirror the system on the other side to obtain more braking power.
The long board he’s using does have slightly larger wheels than normal, but the system could be modified to use on a more standard sized long board.  Stick around after the break to see it in action.
Continue reading “Long Board Takes A Brake” →
