A Vancouver man [007craft], also known as [Michael], posted a video on YouTube about hisĀ living in a storage locker to save money for an apartment. The small space meant he had to incorporate quite a few little hacks to make living there comfortable.
While probably illegal and almost certainly against the storage locker’s terms of service, it seems you can live quite well in a storage locker if times get tough. [Michael] lived in a U-haul storage locker which cost him around $160 per month complete with bed, bar, living area and kitchen including running water. He goes on to explain how his first problem was electricity, which he had to obtain from an outlet quite a distance from his unit, To do this he just plugged in a large extension cord and cable tied it to the wall so it didn’t look too out-of-place, while for his water supply he used two water tanks, one each for waste and fresh water. Surprisingly he says he only needed to change them over around once a week from a water fountain. He did manage to live there undiscovered for 2 months by keeping out of sight as much as possible.
The video includes quite a few small hacks which try to make the most of the tiny space available and is well worth a watch even if you aren’t planning on living in a storage unit, so check it out below the break.
Continue reading “Living In A Storage Locker Undetected For 2 Months”
