Faster Integer Division With Floating Point
Multiplication on a common microcontroller is easy. But division is much more difficult. Even with hardware assistance, a 32-bit division on a modern 64-bit x86 CPU can run between 9 and 15 cycles. Doing array processing with SIMD (single instruction multiple data)  instructions like AVX or NEON often don’t offer division at all (although the RISC-V vector extensions do). However, many processors support floating point division. Does it make sense to use floating point division to replace simpler division? According to [Wojciech Mula] in a recent post, the answer is yes.
The plan is simple: cast the 8-bit numbers into 32-bit integers and then to floating point numbers. These can be divided in bulk via the SIMD instructions and then converted in reverse to the 8-bit result. You can find several code examples on GitHub.
Continue reading “Faster Integer Division With Floating Point”
AVX-512: When The Bits Really Count
For the majority of workloads, fiddling with assembly instructions isn’t worth it. The added complexity and code obfuscation generally outweigh the relatively modest gains. Mainly because compilers have become quite fantastic at generation code and because processors are just so much faster, it is hard to get a meaningful speedup by tweaking a small section of code. That changes when you introduce SIMD instructions and need to decode lots of bitsets fast. Intel’s fancy AVX-512 SIMD instructions can offer some meaningful performance gains with relatively low custom assembly.
Like many software engineers, [Daniel Lemire] had many bitsets (a range of ints/enums encoded into a binary number, each bit corresponding to a different integer or enum). Rather than checking if just a specific flag is present (a bitwise and), [Daniel] wanted to know all the flags in a given bitset. The easiest way would be to iterate through all of them like so:
while (word != 0) {
  result[i] = trailingzeroes(word);
  word = word & (word - 1);
  i++;
The naive version of this look is very likely to have a branch misprediction, and either you or the compiler would speed it up by unrolling the loop. However, the AVX-512 instruction set on the latest Intel processors has some handy instructions just for this kind of thing. The instruction is vpcompressd and Intel provides a handy and memorable C/C++ function called _mm512_mask_compressstoreu_epi32.
The function generates an array of integers and you can use the infamous popcnt instruction to get the number of ones. Some early benchmark testing shows the AVX-512 version uses 45% fewer cycles. You might be wondering, doesn’t the processor downclock when wide 512-bite registers are used? Yes. But even with the downclocking, the SIMD version is still 33% faster. The code is up on Github if you want to try it yourself.
