35 Million People Didn’t Notice When Zynq Took Over Their Radio
What happens when part of a radio transmitting service listened to by over half the country needs to be replaced? That was a recent challenge for the BBC’s Research and Development team last year, and if you’re from the UK — you wouldn’t have noticed a single thing.
[Justin Mitchell] is a principle engineer in R&D at BBC, and just this past year had to transition the audio coding system installed in 1983 to new hardware due to failing circuit boards and obsolete components. The encoding is used to get audio from a central source to broadcasting towers all over the country. The team had to design and build a replacement module that would essentially replace an entire server rack of ancient hardware — and make it plug-and-play. Easy, right? Continue reading “35 Million People Didn’t Notice When Zynq Took Over Their Radio” →
