OTTO, Beat Slicing Interface
otto
Create Digital Music has a great post on [Luca De Rosso]’s OTTO. Built as part of his masters’ thesis, it’s a unique tangible music interface. You load a sample into the software which displays it on the instrument surface. The user can then manipulate the sample using various hardware inputs while watching the LED representation. The device uses just one Arduino for the display and inputs. It works with Max/MSP and is designed to give the performer only the information they truly need. You can find more pictures of the device on Flickr and a picture of the guts on CDM. Embedded below is the ‘Getting Started’ video that shows it in use.
Continue reading “OTTO, Beat Slicing Interface” →
WTPA Bendable Sampler
wtpa
Where’s the Party At is an open source bendable 8-bit sampler kit created by [Todd Bailey]. The initial design started about a year ago when he was instructing circuit benders how to transition to circuit design. He designed the kit to show how simply you could build a sampler. It demonstrates both clear analog and digital design. It’s meant to be a unique instrument though and features a lot of glitchy/quirky characteristics while being fairly reliable. You can read more about the device on his site. It has comprehensive parts and assembly manuals available and the kit is $75.
[via Create Digital Music]
