Rocket Mounted 3D Printed Camera Wheel Tries, Succeeds, And Also Fails
[Joe] at BPS.space has a thing for rockets, and his latest quest is to build a rocket that will cross the Kármán Line and launch into the Final Frontier. And being the owner of a YouTube channel, he wants to have excellent on-board video that he can share. The trouble? Spinning. A spinning rocket is a stable rocket, especially as altitude increases. So how would [Joe] get stable video from a rocket spinning at several hundred degrees per second? That’s the question being addressed in the video below the break.
The de-spun video looks quite good
Rather than use processing power to stabilize video digitally, [Joe] decided to take a different approach: Cancelling out the spin with a motor, essentially making a camera-wielding reaction wheel that would stay oriented in one direction, no matter how fast the rocket itself is spinning.
Did it work? Yes… and no. The design was intended to be a proof of concept, and in that sense there was a lot of success and some excellent video was taken. But as with many proof of concept prototypes, the spinning camera module has a lot of room for improvement. [Joe] goes into some details about the changes he’ll be making for revision 2, including a different motor and some software improvements. We certainly look forward to seeing the progress!
To get a better idea of the problem that [Joe] is trying to solve, check out this 360 degree rocket cam that we featured a few years ago.
Continue reading “Rocket Mounted 3D Printed Camera Wheel Tries, Succeeds, And Also Fails” →
Amateur Rocket Aims For The Kármán Line, One Launch At A Time
When it comes to high-powered rocketry, [BPS.space] has the unique distinction of being the first to propulsively land a solid-fueled model rocket. How could he top that? Well, we’re talking about actual rocket science here, and the only way is up! All the way up to the Kármán line: 100 km. How’s he going to get there? That’s the subject of the video below the break.
Getting to space is notoriously difficult because it’s impossible to fully test for the environment in which a rocket will be flying. But there is quite a lot that can be tested, and those tests are the purpose of a rocket that [Joe] at [BPS.space] calls Avalanche. Starting with a known, simple design as a test bed, numerous launches are planned in order to iterate quickly through several launches- three of which are covered just in this video.
The goal with Avalanche isn’t to get to the Kármán line, but to learn the lessons needed to build a far bigger rocket that will. A home-brewed guidance system, a gimballed spin-stabilized 4K camera, and the descent system are among those being tested and perfected.
Of course, you don’t have to be a rocket scientist to have fun with prototyping. Sometimes you just want to 3D print a detonation engine, no matter how long it won’t last. Why not?
Continue reading “Amateur Rocket Aims For The Kármán Line, One Launch At A Time” →
High Powered Rocket Engines Made From PVC Pipe
rocket
For as much as we enjoy rockets, explosives, and other dangerous things, we haven’t said a word about the works of [Richard Nakka]. He’s the original hacker rocketeer with thousands of words dedicated to the craft of making things move straight up really fast. One of his more interesting builds is his series on building rocket engines out of PVC pipe written in conjunction with [Chuck Knight].
For the propellent grains, the PVC rocket didn’t use the usual potassium nitrate and sugar mixture of so many homebrew solid rockets. Instead, it uses Sorbitol, an artificial sweetener. While melting and casting the Sorbitol-based propellant grains is much easier than a sugar-based concoction,  the Sorbitol had much less thrust than a typical sugar rocket, making it the perfect candidate for a PVC engine.
For those of you wondering about the strength of a PVC engine casing, [Richard] does say making larger rocket engines out of 2 or 3-inch PVC may not make much sense due to the increased chamber pressures. There is a fairly clever reinforcement method for these PVC rockets (PDF warning) that involves using PVC couplers, but the experiments into the strength of these casings have yet to undertaken.
Thanks [Caley] for sending this one in.
