Books You Should Read: The Idea Factory
You’ve heard of Bell Labs, but likely you can’t go far beyond naming the most well-known of discoveries from the Lab: the invention of the transistor. It’s a remarkable accomplishment of technological research, the electronic switch on which all of our modern digital society has been built. But the Bell Labs story goes so far beyond that singular discovery. In fact, the development of the transistor is a microcosm of the Labs themselves.
The pursuit of pure science laid the foundation for great discovery. Yes, the transistor was conceived, prototyped, proven, and then reliably manufactured at the Labs. But the framework that made this possible was the material researchers and prototyping ninjas who bridged the gap between the theory and the physical. The technology was built on what is now a common material; semiconducting substances which would not have been possible without the Labs refinement of the process for developing perfectly pure substances reliably doped to produce the n-type and p-type substances that made diode and transistor possible.
Continue reading “Books You Should Read: The Idea Factory” →
