Let’s face it, automation doesn’t feel quite as futuristic unless you can just say what you want out loud and have the machines flawlessly obey. That is totally possible now — and on the cheap. Well, cheap as far as money goes. It can be an expensive learning curve to get it all working. This will help. [Lindo St. Angel] has put together a guide to navigate voice control of hardware using Amazon’s Alexa SDK.
We previously reported that Amazon’s AI had escaped its hardware prison in the form of the Alexa Skills Kit. Yes, calling it the Alexa SDK above is wrong it’s actually the ASK but nobody knows what that acronym is while most recognize the gist of an SDK. It gives you the hooks and the documentation necessary to leverage the functionality in your own applications. The core functionality of Alexa is voice recognition. Even so, it’s still a tall hill to climb.
[Lindo] has broken down the problem into a very manageable example. The Amazon Voice Service (part of ASK) is used for voice recognition and control. Amazon’s Lambda service connects the ASK to your piece of hardware; in this case he’s using a Raspberry Pi as the server. The final step is to connect your hardware to the Pi. [Lindo] is interfacing a keypad-based home automation system with the Pi but the sky’s the limit at this point.
With all the authentication and connectivity laid bare, this is a lot more approachable. The question is no longer can you connect everything to voice control. The question becomes should you give control of everything over to one single online service?
