Do you remember the Motorola Lapdock 100? It was a CPU-less laptop designed for plugging in your smartphone that enabled you to use your phone as a computer! Perhaps a bit ahead of its time, they never really caught on — but now you can buy them pretty cheap, and with the release of the Raspberry Pi Zero, it was only a matter of time before someone combined the two.
The Lapdock 100 has long been a useful accessory for the Raspberry Pi, but until the Zero came out, it was always a messy bundle of wires running to and from the devices, making it a less than ideal solution. The Zero changes everything. [Ax0n] knew he had to try combining the two.
Continue reading “Turning A Lapdock Into A Laptop With The Pi Zero”
