Mickey Mouse’s introduction to the world was the 1928 cartoon, Steamboat Willie. Not only was it the first appearance of Mickey with sound, it was also one of the first cartoons to employ synchronized sound. The problem is, the sound is awful. Sure, after nearly a century, what do you expect? But [Oona Räisänen] thought it wasn’t just age, but flutter from the original recording. Could it be made better? What follows that question is a self-described geek’s journey into the depths of recorded sound.
The first step was to find a high quality source. The Internet Archive had a copy that was mostly clean. But it also has a lossless scan of the movie including the original optical soundtrack. A quick script played back the original soundtrack and — you guessed it — the flutter is already there. You can see the original 7-minute short from Disney’s channel, below.
